LED Light Kit Install
ഥഎണഡഏ Fellas Inc.
Originally Posted by yunginTL
Ne1 got a link or know how to install an underbody LED Light Kit on the TL?
I ran my wires straight up through the engine bay along the side of the engine bay and wrapped it with electricla first than that those flexible plastic tubes.
The controls were run through the hole that I had in the firewall from previous installs.
Good luck
'99 Acura 3.2TL
if you're not sure about how to install it you might wanna take your car to a professional installer... you dont want to blow fuses and burn wires
but if you feel confident enough to do it i guess you can just mount them like Malayalee King said... make sure you isolate the wires correctly as they will be exposed to the elements... also make sure the tubes are mounted properly and try to make them not too prone to being hit by rocks and such....
justin
justin
trill recognize trill
justin
justin
Sig Rho's Finest
its real easy to do, i did my boys civic in under a hour. it took me bout 2 to do mine cus i wanted to do it right but i hated that mod, i broke the front tube like 4 tims before i ripped the bitch out.
as far as wiring, i doubt you will find a DIY, all i can say is make sure your wires dont come in contact with any moving parts or areas where they will overheat. do as the M.King says, wrap them in electrical tape first
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
