Leather Trim Issues
Old Mar 7, 2008 | 02:04 PM
whudini3000's Avatar
Leather Trim Issues
On the rear passenger side of my car the leather trim has separated from dash? Any Resolutions?
[IMG][/IMG]
[IMG][/IMG]
Old Mar 7, 2008 | 02:20 PM
aznboi2424's Avatar
I think this has been fixed before but on the front driver's side door for a CL but im sure its basically the same procedure. In the DIY, you need to remove the door panel. take some glue i believe and apply then clamp it down. I just saw it a month ago or so, so maybe someone will give the link or you can search for it in the CL forums.
Old Mar 7, 2008 | 02:21 PM
[IMG][/IMG]
[IMG][/IMG]
I actually just got the car back from the collision center and had some really harsh words with the guys there. They claimed it was a manufacturer defect, and I knew it wasn't in that fashion when I drop the car off for repair. (But I can't prove it) They blame it on the hot sun....i beg to differ. But either way I figured we were getting nowhere fast since they wouldn't honor the repair, I decided to just settle with wear and tear... I figured that since it is not a perfect world....my car isn't perfect either.....so thats the history of the situation. I never realized how much I was obsessed with this car....
Old Mar 7, 2008 | 04:32 PM
jjashaa's Avatar
Avant Garde Wheels
yea, i have this situation too. and before, i lived in arizona and most of the time, i parked outside with the blazing sun. being a nbp, it got hot quick inside my car. came to find this little sucker (like yours) coming apart. i jus got some glue and voila, back together.
Old Mar 7, 2008 | 06:04 PM
any particular glue?
Old Mar 7, 2008 | 07:00 PM
1st timer's Avatar
UB6IB9
I have the same problem.I'm going to glue it with some epoxy and tape it in place till the glue dries.
Old Mar 7, 2008 | 07:07 PM
jjashaa's Avatar
Avant Garde Wheels
i would tell you if i knew, lol. i forgot, its been quite awhile
Old Mar 7, 2008 | 07:21 PM
6MTUA5's Avatar
No He Can't
Here's the DIY -- https://acurazine.com/forums/showthread.php?t=187099
Old Mar 7, 2008 | 07:57 PM
erdoc48's Avatar
06 Anthracite TL
Originally Posted by KSuchdeve
This is a very good writeup, but if you want an easier way out, you can use the Gorilla Glue in the gap, then use some clamps (spring loaded) after removing the ashtray in the door panel (pad the pressure points of the clamps)- you can also use a shower rod that is spring loaded to apply pressure to the inside of the door panel (obviously sprung between the 2 doors so that it pushes the door panel back to the normal location of the window switch panel). However, I would use a lot of padding on the ends of the shower rod so you don't indent the door panel foam. I did this to my 00TL with very good results- the Gorilla glue will expand some when dry, but it can be cracked off using an X-acto knife (just be careful not to cut the door panel).
Any comments or disagreements?
Old Mar 7, 2008 | 08:29 PM
Tommy99TL's Avatar
Tom
I have the same problem here on the front and rear driver side doors, I just fix mine recently using couple drops of super glue, spring clips and a firm ruler just like DIY link above but don't have to tear the panel apart (Oh boy, I don't know how can he get a bag of 16 spring clips for only $4, I paid $10 at Lowe's)
It holds up very well so far the next day.
Old Mar 7, 2008 | 08:51 PM
co1063's Avatar
i'll give it a try, which clamps do you suggest and where would i get them?
Old Mar 8, 2008 | 07:06 PM
03typeStl's Avatar
04 Black Infiniti I35
I gotta tell you, I am very dissapointed with Acura work quality ... the TLs feel cheap, they feel like they are made in China.
The materials and the quality of labor are cheap and very weak.
I am glad I sold this car, never again will I buy any Acura .... my Infiniti feels like solid craftmenship, quality materials and assembly, and feels far superior.
Old Mar 8, 2008 | 07:16 PM
6MTUA5's Avatar
No He Can't
Then go bitch about your TL somewhere else
Old Mar 8, 2008 | 07:27 PM
erdoc48's Avatar
06 Anthracite TL
Probably at Home Depot or Lowes (the ones I used in the past came as part of a toolkit- I don't remember where I got those tools). Just get clamps that are spring loaded that will fit in the ashtray area and press against the vinyl without too much pressure. Just be sure to use lots of padding so you don't dent the vinyl/ foam (actually, if you do this accidentally, the foam will pop itself out over time). Also, don't use too much Gorilla glue as it expands when drying (clamps should be left on for 1 day). Then crack off the excess glue with the Xacto knife, and you should get really good results.
Old Mar 8, 2008 | 07:36 PM
aznboi2424's Avatar
I have to admit that my acura does quite a few large and annoying rattles esp. compared to my 92 camry but if this car was made in china, than you would def. know it.
Btw, have you seen the crash tests on chinese made cars on youtube?
Old Mar 8, 2008 | 08:10 PM
03typeStl's Avatar
Thats the thing, thank god I dont have to anymore, its sold.
Old Mar 8, 2008 | 08:12 PM
03typeStl's Avatar
No, never have ... but I have to assume they are very "reliable".
Old Mar 8, 2008 | 08:56 PM
co1063's Avatar
i used "sumo glue" to glue the panels together today. took about 30 minutes of clamping per door panel. didn't eliminate the gap (still a small gap because of the left over glue sticking in there) but it looks much better than before. im satisfied. i agree with 03typeStl that our cars' quality isn't the best but i still love my TL
Old Mar 9, 2008 | 10:53 AM
where is the glue placed? Inside the panel or on the lip of the leather?
Old Mar 9, 2008 | 10:59 AM
co1063's Avatar
i did both
Old Mar 9, 2008 | 11:06 AM
i did both
thanks
Old Mar 9, 2008 | 11:53 AM
Johnny Canuck's Avatar
Stay out of the bar before taking pictures. JC
Feb 25, 2020 09:57 AM
simonbrownTL
Dec 8, 2015 06:09 PM
scionxb3003
Sep 6, 2015 12:19 PM
asahrts
Sep 4, 2015 05:55 PM
