Knock sensors location Acura TL 2003
Old 03-17-2017, 07:27 PM
alebastardo's Avatar
I couldn't find a thread showing the location of the knock sensor. If you know of a thread with this information, please let me know.
I found that a rodent was nesting in my Acura and now the code P0325 is associated with the CEL. The TCS light also is comes on (as other threads here have mentioned). I read that the cable might have been chewed and would like to check it out before going to a mechanic.
Thanks.
Old 03-17-2017, 08:28 PM
Received 16,263 Likes on 11,973 Posts
The knock sensor is hidden below the intake manifold runners.
Old 03-17-2017, 11:54 PM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
Need to remove the Manifold and Intake Runners to see it.
Old 03-18-2017, 08:49 AM
The intake manifold is fairly straightforward to remove...The runners or tubes below the manifold get tricky, as you need small fingers or a swivel ratchet or something to get the bolts behind the runners.
Well I take that back, removing is easy... It's putting the runners and the bolts back on that was tricky.i was pretty frustrated
Old 03-19-2017, 02:30 PM
Thanks guys.
