Just ordered the OE ThermoBlok spacer kit
#41
Boomer SOONER
Originally Posted by NSXNEXT
The intake manifold is definitely cooler. Someone on the CL board dynoed it. Check it out over there.
#42
Dragging knees in
Mine went in yesterday. But the V-AFC II doesn't have the capability to display the necessary data to see what kind of a difference it made. For now, I'll have to be content with the fact that it made a difference in other people's cars, and did so as well in mine.
#43
You have had it installed for some time now. Would you still recommend it? I plan on cleaning out the intake manifold soon & that would be a perfect time to do this as well.
#44
#45
Boomer SOONER
#46
Resident Troll.
1 Post
The spacers do make a difference but its hard to say if its cleaning the intake manifold and TB that really give you the difference or if the spacers provide the gains. The intake manifold does run cooler and the gains are there but cleaning everything out probably helps out a bit more!
#49
#54
Boomer SOONER
Originally Posted by moahdriven
for those that have this on already...did u guys install the spacers by urself?
#55
Instructions were very straight forward and eay to follow.
#56
im really thinking about the spacers too , seems like its good gains but at what cost? how much hotter does the engine get and will that damage or cause faster wear? secondly im ok on installs that are minor , would this be something that most people capable of putting in an intake or changing spark plugs can do ? I dont have $150 for the 3 hours labor a shop will charge
#58
#59
#60
i am really interested in doing this mod eventually (once i have the time and money... a 6week old + 2yr old will have to take priority right now), but have always wonder what's involved and what are the steps.
If someone decide to do this themselve, could you try to take a lot of pictures, and possible make it into a DIY page?
That will be totally awesome.
#62
Dragging knees in
Originally Posted by TLsu
How much HP can we expect to gain from a spacer kit. I guess you would have to dyno the car to know for sure...but I'm just looking for an estimate.
#64
Hey guys, it has been a while.... for anyone interested, I have the thermo block spacer kit, never installed. If anyone is interested, I can consider some negotiation.
My friend installed his, and the diffrence is noticible as stated in the thread, it is a mod that's worth the money and time.
Reason: Planning on changing my TL..... for...... another TL
Hit me up if you are interested.
#65
this is just a quick rundown, some pics in this link
http://www.acurainspired.com/forums...?showtopic=4003
and this link
https://acurazine.com/forums/showthread.php?t=116316
Post #4
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
#66
#67
Hey guys, just to make sure... I'm assuming that the 99 kit is diffrent from the 00 - 03 right? Owtlaw's website makes a distinction at the order page.
Please help clarify, I will be getting an 03 TL-s in the next couple of days, will my current 99 kit fit this set up?
Thanks again!
Thanks again!
#68
Dragging knees in
Outlaw first came out with the '99 kit, and everybody (besides the '99 owners) was disappointed because we were told that it didn't fit '00'-'03 models.
I believe the intake manifold design is different, hence the reason they are not interchangeable between the years. You will have to get a new kit, probably.
But really, your best bet is to call up Outlaw.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#70
UB6IB9
Originally Posted by crombie1000
I was wondering the exact same thing myself. It would seem that any gains due to cooler intake would be counter-acted by a hotter running engine. Also, higher heat = more wear and tear on the internals(right?)
#71
UB6IB9
i asked them what they think about a hotter running engine and they replied:
Why would the engine run hotter? Any heat not absorbed by the intake (a minimal amount of the total heat produced) would be transferred to the cooling system and dumped to ambient
#72
#74
Originally Posted by Pure Adrenaline
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Thus, the Mugen cooling mods would be a very nice addition to the spacers.
mrkingstonvi
02-22-2016 01:53 PM
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
mtl_ilx
09-03-2015 09:48 AM
