Just installed strut and sway
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
spent around 2 hours putting in my neuspeed strut bar and front comptech sway. first the neuspeed didn't fit, so had to relase the third bolt, and then jack up the car from one side so that the front would bend, and it took a lot of force to squeeze that thing in. but finally did get it in.
the comptech sways took a while too, and so didn't have time to install the back one yet. i only had a small floor jack to work with, and it didnt lift the car much.
an advice for people working with just floor jacks, it might be easier to take out the wheel, and work on the sway bar from there. thats wut i did, and i thought it was much easier than sliding under the car where i barely had enough room to move my arms.
well i'll b installing my rear bar today, and i also changed all my interior lights to Polarg M4's. i didnt change the dome light yet, cuz i couldnt find a nice one to match the M4's. anyone have any suggestions on wut to get for my dome?
Re: Just installed strut and sway
aiight, jus finished installin the rear sway bar today. took like an hour. however, i forgot to put the teflon tape on the bar...does anyone know if the tape is important? and whether i should go through the trouble of reinstalling it to wrap on the tape??
performance wise, i feel there is a noticable difference. but i dunno if its the struts or the sways cuz i put them on at the same time. i dunno if the improvment was worth the price thou, $400+?i'd say the springs were a better investment. but i guess since you already have the springs, the next thing for handling improvments would be the strut and sways...
The tape is to help prevent squeaking from the rear sway bar. It does work! I just applied more tape on mine and the squeak went away. If you end up using tape, I'd recommend not using any grease.
The Sways alone works great but in addition with the upper strut it gives you a tighter feel.
Originally posted by thephantom
Interesting. When had mine done we put the teflon tape on the bolts, not on the bar itself. However, I did apply the included grease onto the bar and I didn't have any squeaks.
has anyone done the sways.. then the struts later to see if theres much of a difference???
The sways make a pretty big difference but I'm wondering if its even worth it for the strut tower braces.
marcelft
07-10-2018 06:17 PM
acurajj
02-14-2016 02:28 PM
MonkeyTrucker
09-21-2015 06:15 PM
