Just got my clear lens spoiler led
Old 01-20-2003 | 04:07 PM
  #41
this is me's Avatar
Originally posted by axleback
Ok, time to dig up this ancient post. How's everybody's LEDs holding up? Mine is starting to blink erratically on the right most 5 LEDs. Annoying as hell. Don't know if it has anything to do with the sealing adhesive copland mentioned above. During initial installation, I made sure the original adhesive doesn't get damages so I could reuse it. This might not be good enough? Upon closer inspection, I can see the inside plastic casing is all fogged up! I just sent spoiler.com an email asking them if this is covered under warranty. Let's see what they say.
axleback
how long urs been??
i had mine since the fall and i dunno if it does the same. i'm usually alone and i cannot make the brake light light up by myself. But i will check and give you an update on it. Last time i checked(dec) it was fine.
Old 01-20-2003 | 06:53 PM
  #42
copland007's Avatar
Having Fun?
I noticed that the leds weren't perfectly lined up anymore on the left side. I'll have to check to see if they light up correctly and get back to you.
Old 01-20-2003 | 10:37 PM
  #43
AndySara's Avatar
Next time when you go grocery shopping.....before you take them out of your car, use the gallon of milk, cartons of OJ or your two liter soda bottles by propping then up against your brake pedal.
Easy way to test the brake lights.
Old 01-21-2003 | 11:19 AM
  #44
axleback's Avatar
Well, I just got a reply from spoilers.com. The customer rep. was very friendly and didn't question me at all. He simply told me to send the defective LEDs back for a free replacement. I had mine since July. When I get my replacement, I'll make sure I seal the baby in that opening as tightly as possible this time around. To those that simply just slap the new LEDs on without replacing the PSA, I suggest you check yours for fogging too. I believe the excessive moisture is the main culprit here. You'll be surprised how well a piece of poron pad insulates.
axleback
Old 01-21-2003 | 12:24 PM
  #45
Laurelcrest's Avatar
Advocatus Diaboli
If anyone has gotten this done in Toronto, please let me know where because I want it it looks hot!
Old 01-21-2003 | 08:06 PM
  #46
this is me's Avatar
i put a brick on the pedal and nuthin happens! i can check it with my bro though.
Old 01-21-2003 | 09:23 PM
  #47
rmarin2's Avatar
Well I just tested my lights and they all work fine. I did notice that if u look at them from underneath the row of led's isn't straight. I don't know if it was like that before but it doesn't seem to affecting light output in anyway.
-Rich
Old 01-22-2003 | 12:02 AM
  #48
copland007's Avatar
Having Fun?
-Rich
Same here, not all lined up but they all light up.
BIGxRED
10-19-2015 10:47 PM
stogie1020
Cameras & Photography
17
09-30-2015 01:34 AM
spoiler900
09-23-2015 04:41 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Just got my clear lens spoiler led
