Just Did fog light mod and...
i dont know whethere i messed up or not because the left fog bulb shattered out of know where and then i replaced it and that one went out? Can some one please help me.. the left one seems to be just fine...?!?
Did you happen to touch the bulb with your fingers? The oils from your finger can heat up enough to shatter the bulb. If the second one went out then your probably touching the bulb with your hand or finger. You can not touch the bulb at all! try wearing rubber gloves, that should at least keep the oils away.
That is the only explanation for the shattering of the bulb. When I did my 6000k fogs, I was very careful not to touch it, but I guess I must have and when i turned it on testing it before putting it into the housing itself... i heard sizzling and saw smoke being given off, i immediately had my friend shut it off!!
We wiped the bulb and problem solved. Its the oil on our fingers that does this.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
oyayjoe
09-12-2015 04:40 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
