Just bought a 2002 Acura 3.2TL Type-S
Old 02-14-2010, 11:04 PM
runtohell121's Avatar
So.. I bought a salvaged 2002 Acura 3.2 TL Type-S, what should I do now? what kind of tune up should I do? It has 111,250 mileage on it. What kind of oil should I use? along with filter and spark plugs for this car?
Old 02-14-2010, 11:56 PM
Bonki' Ehrite!
ANC297's Avatar
What should you do now? Start modding...I use 5w-30.
You can upgrade your filter to a CAI for better mileage and performance. NGK Iridium is the stock plug and thats what is recommended.
Find out if timing belt service has been done or not, if not take care of that ASAP.
For some reason, your hood does not look right.
Old 02-15-2010, 12:00 AM
How do I know if the timing belt has been changed or not? CAI would probably be too expensive for me to get xD... How much are the spark plugs?
Whats wrong with the hood? Maybe it's just the angle where I took the picture? xD
Old 02-15-2010, 06:55 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
have it looked at. If not you better start saving up. It is something you will have to have done if you dont want to worry about blowing up your motor. The timing belt service will run between 600 to 1200 depending on the shop you bring it to. CAIs can be bought used for decent prices or up to 200 new. Plugs are anywhere between 40 to 60 bucks depending on the deal you find for the 6 of them.
Old 02-15-2010, 07:47 AM
bruistopher's Avatar
nice pick up
i would register with myacura.com and see if your tranny has been replaced or not. it will either say opened or fixed on the recall.
i would check under the hood and see if you see a oil jet on top of the tranny where you would put the new tranny oil in. that's another recall.
i would suggest since your at 111k to get or check to see if you did the timing belt, water pump, tensioners, drive belts, coolant flush, brake fluid, power steering fluid flush, pulleys for the timing belt.
all those factor in your car going another 100k and its well worth it if your going to keep it.
also on some 02-03 there is a recall on the timing belt pulley, it adds pre mature wear to the timing belt shorting its life so definitely get that checked out.
oil, i would use any oil thats 5W-30. i use castro gtx. as far as air filter. you are optional to use CAI, K & N air filter.
i personally would check the tranny fluid level right now for level and for the smell to see if its burning the 3rd gear clutch pack. because in these trannys (02-03) they usually die out due to a poor tranny case design especially for the added 5th gear. they basically took the 99 tranny case and squeezed the 5th gear into the tranny case. heat builds up especially on the 3rd gear clutch pack since its at a weird design angle
just check those out please, but that's a awesome ride and i hope all is well with it
Old 02-15-2010, 10:47 AM
Well, I already registered with myacura, it says my car is one of the ones that was recalled for airbag and the transmission problem wasn't fix yet either.
edit: I actually have a drop in K&N air filter from my 1999 Honda Accord V6, does it fit? will it harm to engine? xD
my dad is planning to replace the engine oil, transmission oil, and spark plugs.
Old 02-15-2010, 10:51 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
you will get covereage on the airbag but not the trans warranty since you are salvage
Safety recalls are honored including the seatbelt and SRS warranties to 10/150
Assume the 105 timing belt was not done, and get ready for it soon-
look for any clean parts or slight edge marking on bolts to front cover indicating someone was in there recently
Old 02-15-2010, 11:03 AM
meh.. most likely we will replace it to be safe.
Old 02-15-2010, 11:10 AM
Here's the list of recalls..
Description 00-04 CL & TL A/T RECALL Date 06/29/2004 Type Recall Customer Letter Status Fixed Your 2002 Acura is included in the DRIVERS AIRBAG INFLATOR Campaign.
Description DRIVERS AIRBAG INFLATOR Date 07/20/2009 Type Recall Customer Letter Status Open Your 2002 Acura is included in the 2000-03 TRANS WARRANTY EXT Campaign.
Description 2000-03 TRANS WARRANTY EXT Date 09/27/2002 Type Recall Customer Letter Status Open
is there any more recalls other than those 3?
Old 02-15-2010, 11:24 AM
2000 acura tl FPR
assclown's Avatar
are those tsx wheels?
Old 02-15-2010, 11:26 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Congratulations!
Old 02-15-2010, 11:36 AM
I actually have no clue.. anyone know what acura wheels are those? lol
Should I go genuine on the belts? it's like $342+ from a store on eBay
http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
Old 02-15-2010, 11:48 AM
greg4771's Avatar
If the tranny has gone to 111,000 miles with no work on it, at this point I wouldnt even worry about it anymore. Obviously its a strong one.
Old 02-15-2010, 11:50 AM
greg4771's Avatar
Those wheels are deffinently off of something newer. Either a TSX or a TL,
Old 02-15-2010, 11:57 AM
I have a question, where's the OBD II plug
Old 02-15-2010, 12:05 PM
never mind, found the OBD II port
Old 02-15-2010, 12:28 PM
sorry to tripe post, but I have another question.. When the car is in "P", I can't rev up above 5k rpm? Is it locked? Will I be able to rev over 5k RPM when i'm driving?
Old 02-15-2010, 03:27 PM
yes its suppose to stay at 5k rpm when in park at idle but once in D5 and you floor it it will go all the way up to 6500 rpm and then shift to the next gear.
do not overdo the rev limiter in park dude!
Old 02-15-2010, 04:45 PM
heh.. i won't. I was just wondering why it couldn't go pass it
Old 02-15-2010, 06:29 PM
quick question, what is the best oil filter and oils for this car? I was thinking about getting Mobil 1 Full Syn. and possibly a cheap oil filter from wal-mart (Supertech)?
Old 02-15-2010, 07:39 PM
I live in
nhn23's Avatar
yes those are the TSX rims. i have those as my winter setup with blizzaks.
Old 02-15-2010, 08:28 PM
01tl4tl's Avatar
supertech are not great- dont even have anti-drainback valve!
spend a few dollars more and get a K&N or M1 filter to go with m1 extended/high mileage
or your choice like penz platinum
run seafoam in oil before change to clean oil passages and freshen the motor
5k rev limiter is to protect the motor- like showing off your quick rev light crankshaft pulley in a parking lot ziner meet-
There is also a rev limiter in your SS mode of shifting so you cant do a downshift too fast, and normal D5 driving- hit redline and it starts a stuttering feeling until you release some throttle
register with acura.com and 1-800-382-2238x5 need vin for both- different systems of acura but both should know what you need done
open on recall means needs to be done
you are part of the 7.9/109 extended trans warranty group
Old 02-15-2010, 08:33 PM
01tl4tl's Avatar
some 02-03 get a free timing belt job- call acura to see if part of that recall
you pay for water pump and tensioners- they do the rest as warranty for bad pulley
a dealer on here has the complete 105 package of parts they use at the dealer, with all the belts, idler and tensioner pullies for timing belt- about 300- shipped! deal!
see thread- some love for valentines or pm WholesalePartsGuy
Old 02-15-2010, 09:06 PM
Seafoam won't hurt my engine right? I was planning to do it today with my 98 integra but after reading some post in another forum saying it harms the engine..
So K&N oil filter is the best to go? I see at Kragen, they have "Royal Purple(?)" engine oil+K&N oil filter for $40...
I can't just take my Acura to the dealer and get them fix it without any appointment or anything?
Old 02-15-2010, 09:39 PM
how are Denso Oil Filters?
http://www.amazon.com/Denso-150-1006...tive&carId=003
My dad wants to go cheap on oil filters... but getting Mobil 1 for Oil.. ><
Old 02-15-2010, 10:42 PM
niju321's Avatar
You'll find a lot of love in the TL forums for Seafoam--many (including myself) swear by it. I have supervised use of Seafoam in my own 99 tl, a lexus ES (which made a spectacular smoke cloud, but it had 180k at the time) and a saturn sl (which, with seafoam, hit 90 for the first time!) Just wait till 01tl4tl sees this
As for the oil, the last time I checked Advance Auto Parts had a special...5 quarts Mobil 1 Extended Performance (the best synthetic oil they make) and same brand filter for $30 or so...I'd check that out first
Denso is an OEM supplier for Toyota IIRC...perhaps they are OEM filter suppliers for Acura as well? Not sure on that one though
Old 02-16-2010, 03:53 AM
01tl4tl's Avatar
denso will be ok- so are NAPA filters- Wix, the fram orange ones are made cheaper, like supertech
What you will want especially after seafoam the oil- is a good filter!!
RP oil is nothing special and m1 m1 package is good
Any major name brand oil will be fine- synthetic optional
Seafoam will not hurt anything- safe for sensors/cats and does burn in the engine- just not very well
follow the diy on here, last pages for current info, and add slowly to manifold vac port. add 1/2 can to oil and drive 30 minutes before change
Old 02-16-2010, 03:58 AM
01tl4tl's Avatar
you need an appointment for most things at the dealer, there are x amount of techs and certain jobs require a certain level of certified training and the parts may have to be ordered
With major recalls you really need an appt, and waiting around for the car to be fixed is a bad plan- drop it off and wait for the call that its ready
loaner car to those over 21 or 25 if available
as example the toyota recall says only `senior level techs` can perform the job, thats a very few of the staff that have been there for years... not all of them
Old 02-16-2010, 07:18 PM
got the car registered today and bought insurance, failed the smog check lol..
I guess it's the battery.. we changed the battery without driving it after the replacement (old battery was dead)
Old 02-16-2010, 08:03 PM
Vman159's Avatar
welcome to the forums! dont let the modding bug bite you or else you MIGHT go broke
Old 02-16-2010, 08:12 PM
Lol, I'm not really planning to mod it, maybe just the fog light. I'm debating whether to get HID Fog or just halogen fog, 3000 Kelvin bulbs of course
Old 02-16-2010, 08:26 PM
Oh yea, my stock head unit is missing from the previous owner, taking away the audio system with his after market things that was hooked up in the rear trunk. I'm planning to get a aftermarket head unit, but hows the sound quality?
Old 02-16-2010, 10:43 PM
Vman159's Avatar
I like the BOSE sound quality but for some people they say it isnt good enough for them.
Old 02-16-2010, 10:54 PM
Well, I would have keep the bose system, if it came with it.. but the previous owner(s) took them off.. and replaced it with their own.. and when they sold the car to me, it didn't come with any stereo. I don't know what to replace it with, planning to replace it with a 3" DVD player head unit.. or possibly just a cd player with sd card/usb slot that supports mp3
Old 02-17-2010, 09:29 AM
01tl4tl's Avatar
when you change/disconnect the battery the ECU resets and can take up to a month of normal driving to relearn everything for Smog test- its a safety device to keep people from clearing a code and passing smog~
there is a method of specific driving you do for 45 minutes so it makes a fast relearn and can get smog
Old 02-17-2010, 09:30 AM
01tl4tl's Avatar
for actual fog just plain fog lights work
HID is for looks on them, too much light for real use
Old 02-17-2010, 12:13 PM
really? I kind of want something yellow, thinking that it would have give more visible light output on the road as fog lights xD..
Old 02-17-2010, 12:14 PM
what is the fastest way? My dad is planning to drive it for 2 days (50 miles each day) 100 miles total.. would it relearn everything by then?
Old 02-17-2010, 04:41 PM
I was wondering what's the mileage on this car and how much will I get max out of the full tank?
Old 02-17-2010, 05:04 PM
phillie's Avatar
Very nice, love the color!!!
Quick Reply: Just bought a 2002 Acura 3.2TL Type-S
