jack point
jack point
Hi guys,
This is my first post. =)
I did search but I couldn't find an answer what I was looking for.
ANyway, I have a floor jack and want to left whole front and want to place jack stand.(my car is 2000 TL)
But I couldn't find a jack point.
Where should I jack?
I want to replace engin mounts.
Thank you guys.
Thank you guys.
look under the front of the car- with a 4x4 block of wood on top of the floor jack
you can lift from a middle point in front--it sticks out when you look
jackstands go under the frame rails inside of the normal lift points on sides
Those are identified by the double thickness of metal, and a cutout in the metal for the regular car jack to fit into
Located near the door ends
Caution! Place a secure block behind the rear wheel or car will try to move around on you
ck our diy section for how to replace the mounts correctly and safely
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
thanks for clarifying kris,,maybe I was thinking of the rear for the wood block,,and my crappy hft jack with the small pad
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
