J35/J32 6MT Build
J35/J32 6MT Build
Ok so this will be my first time ever assembling my own motor & I wanted to see if you guys could offer some insight and help me put together a parts list. Right now I have a j35a3 block, j32a2 heads, & an 05 TL 6speed. My current plans are to go with the j37 intake manifold, cnc ported runners & b series throttle body. The main things I'd like to know tho is what are the parts (timing components, stuff around the block) that I need to mate up the heads and tranny to the block. Any advice is appreciated !
I know I need 05 RL Pistons to clear the valves, a butterfly delete kit, & Id also like to delete the EGR.
What exact gaskets do I need to get ? would it be a j32a2 headgasket or a j35 headgasket ? sorry if its a dumb question but thats what fouls me the most, would I need a j32 intake manifold gasket or a j37 gasket ? which timing components should be converted to manual ones ? do I need a starter from a manual ? a more powerful alternator ? Recommend some mounts !
If you populate the search field, on the link below, with either 'J35A3' or 'J35A3 swap' , you will find answers to your questions because it is all here somewhere.
AcuraZine - Acura Enthusiast Community - Tags
False. Both the J32A2 and J35A3 pistons will clear the valves.
Just pretend you're assembling a manual J32A2 engine. This means all the timing belts and gaskets should be for a manual J32A2. The J35A3 has the same exact block case as the J32A2, so everything will match up.
CSmoney28
12-19-2020 09:58 PM
RJNN TL
10-09-2010 12:12 PM
