Ironman + Intake Manifold Cover???
So a friend of mine who sold his CL-S gave me his manifold cover already painted nicely. I put it on and i realize I need to match the paint on the lower part that is still black and I want to get a battery cover matched and all the little black boxes under the hood.
I was looking at the paint on this cover and everyone says the same thing. "It looks like Iron Man's suit"
So I thought I would photoshop the valve cover to be slightly golden to see what it would look like.
What do you guys think? Excuse the dirty engine bay.
BEFORE:
AFTER:
And what is the best way to get the valve cover painted? powdercoating? I know it gets extremely hot
BEFORE:
AFTER:
The Dumb One
i say finish your intake mani and lower piece... and get yourself that battery cover. fin/
yeah soo true dont paint the battery cover, you will OVER do it and it will look cheap and ricey...
B A N N E D
everything is there other then the cover itself, and the reason for it not being there, probably did not fit with a new battery, so it was never put back on/tossed (factory battery has those vents/caps recessed with the rest of the battery)
but it's nothing that a dremel or tin snips won't fix (just needs some clearenceing on the underside), doesn't have to be perfect cause it is on the bottom of the cover, so only bill be seen by you, or a shop
B A N N E D
see those two little rubber grommets on the side of the battery, it attaches to those on that side, then it slides onto the J-bolt (what holds down the tie down and battery) on the other side, and by the looks of it, it might need to be trimmed also, with how far the one that can be seen is protruding up
rcs86
08-02-2016 06:52 PM
