inspire footwell lighting
Old 12-10-2003, 06:14 PM
john32's Avatar
Arrow inspire footwell lighting
I know this subject has been brought up a lot, but i was wondering of some places that sell a set?
Old 12-10-2003, 06:29 PM
hzm82's Avatar
Just buy the 10" neon light stick from wal-mart and hook it up. Total cost is like 26 dollars.
Old 12-11-2003, 02:42 AM
UA5-TL's Avatar
or if you don't want to use neons just buy bulb housings from your local hardware store...and some xapstraps as indicated already. oh yea be ready to do some wiring too!!!! so long pieces of wire and i didn do any splicing but some ppl on the board have!
here are mine
Old 12-12-2003, 10:58 AM
IhuynIh's Avatar
UA5, do you have instructions on how you did yours? are they any white ones? or would the flourescent ones work? do they draw out much wattage?
thanks
Old 12-14-2003, 12:48 AM
UA5-TL's Avatar
lol i think if you use the flurescent bulbs you won't have the dimming effect....i stuck with the "yellow" bulbs b/c it matches everyhthing else i have that's "yellow"
but there are quite a few instructions on here on the board if you search for it. its quite easy you just have to hook the positive to a constant 12V power and hook the groun to the fuse of the dome lights but do a search that would give you a better idea cuz they have circuit diagrams and instructions
Old 12-14-2003, 09:39 AM
hzm82's Avatar
http://www.acurainspired.com/forums/...showtopic=2109
Old 12-14-2003, 09:43 AM
hzm82's Avatar
Go find two white neon stick around 10 inch. They will fade with the dome light.
Old 12-15-2003, 08:37 AM
2007AcuraRL's Avatar
Are those true neon bulbs or the cold cathode ray tubes? I know the label on the box says "neon" but real neon bulbs usually require a high voltage transformer.... Just wondering...
Old 12-15-2003, 05:30 PM
BlingBling INSPIRE 32V
songoku's Avatar
I got this 12 inch for $20 each. It's white. Pics will be posted soon.
Old 12-19-2003, 12:01 AM
rmarin2's Avatar
I saw those at Target.. they have 8 LED's right? How is the light output from those?
-Rich
Old 12-19-2003, 07:29 AM
Bxscig's Avatar
Are the regular ones brighter or the LEDs brighter? I got these from walmart over by green acres, looks like the same ones as hmz82.
saberlove
03-11-2021 09:29 AM
02-25-2020 09:57 AM
InFaMouSLink
10-27-2015 06:51 PM
09-21-2015 08:44 AM
09-14-2015 03:16 PM
Quick Reply: inspire footwell lighting
