Indiglo gauge power source??? Help!!!
Locate your driver side fuse box. Then lay on your back and stick your head under the stearing wheel area. Look at the back side of the fuse box with a flashlight. There are some little rectangular connector slots. One of them is marked #3. Use this one so that when you turn your lights on the guages come on too. You will need to get one of those flat slide-on connectors and an inline fuse. The other wire goes to ground and can be attached to anything metal under there. ie loosen a screw and connect the other wire.
I can't stress enough that before you put your guages back together make sure that the inner diameter of the overlay is stuck down pretty good or else the neddles will stick at some point.
Good luck.
Good luck.
hey bro,
you bought the gauges? congratulation bro. It should be under the dask. Like the other guy just say. It so easy. Just put alot of tape in the middle so the needles won't get stuck. Also put a fulse so it won't burn on you. Post some pix. i really want to see how your car look bro.
BlingBling INSPIRE 32V
Please review other member's problem before installing it.
http://www.acura-tl.com/forum/showth...threadid=34600
09-25-2015 06:14 PM
