im so screwed what in the heck should i do?? (tranny/spring question)
Did you crack the boot? And is the car under warrenty still? Usually, CV boots don't crack till long after the warrenty, unless you pulled on it when you tried to take the half shaft off. (Always pry from the splined end) either give it to the dealer, or buy a kit that Honda has to rebuild the half shaft (grease, boot, clamps, etc) A failed CV joint doesn't make grinding noises either--esp "between gears"...more of a clicking or whirring noise. Good luck!
Peach Tea
Peach Tea
Originally posted by ArN 2000 TL
first mistake was posting this on the forum..dealers DO read this type of posts....be carefull.
navtool.com
09-25-2015 05:15 PM
