Idle isn't smooth
Old 02-15-2006 | 01:15 AM
kt411gcn's Avatar
Idle isn't smooth
Hi everyone, my engine has been acting a little strange lately, im hoping that it's not a sign of bad things to come. Im at 100k on the engine. Here's what's up- when i start up the car, it will idle a bit high (around 1k rpm) for a few seconds, then gradually goes down to about 750-500 rpms where it idles normal. This has only started to happen recently.
Also, my engine doesn't seem to idle very smooth. If you guys can imagine a v8 with cams, except this doesn't sound like cams. The sound pattern is similar, though. That is the best I can explain it, but is this normal for tl's when they get up there in mileage? It sounds pretty bad from outside the car, doesn't sound very luxury-like. If it makes any difference, i've had an intake, header, and exhaust since 20k miles.
Old 02-15-2006 | 06:10 AM
brado's Avatar
new wheels = old school
i'm the same right now on my 99 with 85k miles. i hope doing the plugs and timing belt will cure the bad idle going on. anyone else?
Old 02-15-2006 | 09:33 AM
phipark's Avatar
Not Asian
Time to change the plugs.
Old 02-15-2006 | 01:35 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Mine idles at 1250rpm when cold for about 30 seconds before dropping to 750rpm normal idle speed. A variation in this, or erratic idle is usually IAC valve problems.
About the rough idle, that is probably more than just plugs. Better have that checked.
Old 02-15-2006 | 01:51 PM
dvsxlt247's Avatar
99TL-p 114K
I idle at 500 nice and smooth. Doesnt sound ruff or anything. I do plan on chaning my spark plugs to the Bosch Platinum +4 plugs which i already bought but i just havent put them in yet. Those might make me idle even better lol.
Old 02-15-2006 | 01:58 PM
03CoupeV6's Avatar
The normal idle is 750rpm. At 500rpm the car would be shuddering.
This is a picture of a 99 TL at idle with a normal idle speed:
Note the tachometer can be confusing. The first bold line above 0 is 500. The first normal line on the tachometer is 750, and this is what a normal idle speed should look like.
Old 02-15-2006 | 03:35 PM
khoifl's Avatar
Not to burst your bubble, but I had Bosch Platinum +4 for my old 91 Celica and it did not make any difference (performance or mpg). In addition, I came across a thread that told Bosch Platinum +4 is hot for our car. You are better off w/ NGK Iridium or Denso Iridiums (heard that great plugs but don't last long).
Anyway, someone corrects me if I'm wrong.
Oh yea, 500rpm idle is a bit low. Mine (52K 02TLP) also starts at 1250rpm when cold, and drops down to around 750
Old 02-15-2006 | 04:02 PM
dvsxlt247's Avatar
99TL-p 114K
Yeah thats how my idle looks. Sorry, everytime i see on mine how the idle looks, i keep thinking its 500 when its not. So then yeah, my car idles at 750. Thanks for the correction.
Old 02-15-2006 | 04:04 PM
dvsxlt247's Avatar
99TL-p 114K
you aint burstin no bubble. Ive heard all the bullshit on the bosch plugs. Ive also talked to people that have them and have had no problems. Anyways, i havent installed them yet but i could always take them back. Its not like my TL really needs new plugs now anyways, i dont even know why i went out and got them. Maybe i should just order NGK or whatever then.
Old 02-15-2006 | 10:59 PM
kt411gcn's Avatar
It actually idles at normal revs of 750 rpm after a few seconds of startup, sorry for the confusions. Im definetly going to get it checked out plus get new spark plugs, I need to bring it in for an oil change anyways.
Mike734
12-10-2021 02:25 PM
DerrickW
11-15-2015 06:52 PM
adreano17
09-29-2015 09:48 AM
mdlex389
4G TL Problems & Fixes
09-28-2015 07:29 PM
prbori
09-27-2015 02:37 AM
