AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G TL (1999-2003) (https://acurazine.com/forums/2g-tl-1999-2003-98/)
-   -   i need wiring diagrams.. (https://acurazine.com/forums/2g-tl-1999-2003-98/i-need-wiring-diagrams-912495/)
MrMoAcuraPar 06-09-2014 12:07 PM
More specifically, wiring diagrams of the dome light trigger into the harness... trying to add some lighting that operates off of it and the diy section has left me much to be desired. Any help would be greatly appreciated, guys
jjashaa 06-09-2014 01:15 PM
it's on the passenger side fuse box side..
i tapped into white/blue and black/something wire
(click for full resolution)
https://farm4.staticflickr.com/3864/...98f119d1_b.jpg
take a picture of the passenger fuse panel then I can probably pinpoint out which wire on which plug i tapped into if I can remember
MrMoAcuraPar 06-09-2014 04:42 PM
You're the man!!! Exactly what I was looking for, but I'll take a pic ASAP for easier clarification. I really just needed the power side of it anyway, I can make a ground happen wherever I need to.
MrMoAcuraPar 06-09-2014 04:54 PM
On second thought, maybe I can ask some advice, so here goes;
I'm interested in wiring in some leds for the door handle mod found in the diy section. Do I just wire the pos. side to the blue/white wire and create my ground wherever I'm able to?
jjashaa 06-09-2014 05:19 PM
mmm.. i don't really remember.. but I remember when I had one ground going to the negative battery terminal, it would turn on the lights.. in this case, mine were puddle lights.
so i had a switch to change between ground from negative terminal to the wire harness ground... so if it were to just be grounded anywhere.. it might just stay on from what I remember.
just looked at the door handle LED and just follow that one.. didn't realize, after all these years, that that thread had all the pictures needed.. haha
Black wire w/ white stripe and 2 silver repeating marks (NEGATIVE)
White wire w/ blue stripe and 2 silver repeating marks (POSITIVE)
MrMoAcuraPar 06-09-2014 05:22 PM
I've tried to follow the pictures in that thread and come up with nothinh, honestly. It's kinda vague IMO. Asked for clarification on that thread (you probably saw that) and got no answer from anyone, which is why I started this thread...
jjashaa 06-09-2014 05:30 PM
splice into the wires i mentioned above
MrMoAcuraPar 06-09-2014 05:49 PM
Cool bro, thanks!!
