i made a HUGE mistake, is my car ok??
Peach Tea
![Red face](https://acurazine.com/forums/images/icons/icon11.gif)
ok, so yesterday i took off my 18s and put on stock 16s for winter. while doing so i had my e brake on and when i finished i forgot to take it off. now since there is snow and ice on the ground, i thought the reason i wasnt moving is because it was slippery.
so i took my car on the interstate, with the e brake still on and i got up to about 90mph. when i got back my friend (who was driving in another car) said "damn dude i smell brakes!" so i was like OH S#!t and i look down and see my ebrake is still on. did i damage something? i dont usually use the e brake anyway...
Re: i made a HUGE mistake, is my car ok??
good luck with that.
beside the e-brake pad worn down to nothing, the drum might warped and (not to scare you with the TL famous tranny defects) you worked your engine and transmission quite hard during that time. The rear brake probably overheat. Beside checking the pads and drums, check the brake plumbing for leak, check the tranny fluid for abnormal discoloration too.
And if i remember correctly, the manual said that driving with the e-brake on you might damage the rear axles ... (probably not)
The emergency brake uses a drum in the rear wheels, it uses the discs when you are driving. You may have affected the use of the emergency brake, but the disc brakes should be fine.
New Life
Originally posted by Bigmonkey70
yea we have disk for normal brake and drum for e-brake
We have 4 disc brake system. Please check your info before you pass the wrong information.
Originally posted by maxx96
What the......You better look at your car because if I ever think about having drums for the rear brake I'm running to the dealer to turn in my car.
'99 Acura 3.2TL
dont worry corey, just get your pads (e-brake pads inside the hub) checked... you will probably need new ones.
and maybe u can get the wire checked... might have stretched or somethin'
@cUr@-TL
@cUr@-TL
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
Originally posted by fsttyms1
the rear of our car has disk brakes for normal stoping. our parking braks IS A DRUM! the drum part of the brake is in the hub part of the rotor, so Bigmonkey 70 is correct!
allittle late in winter to change rims isnt it?....im waiting to put my 18s back on!
anyway....should be fine....once you get moving the stress on the engine and trans isnt that great.....you probably just need new pads and get your parking brake cable adjusted...altho the pads arent designed to be spinning inside the hub...you might want to check the hub for wear...and you might need new rotors if the hub has worn to thin...but you'll know soon enough if the rest of the rotor warps
ive got 3 winters of parking brake (donuts and such)
on my parking brake and its still fine, and ive also used mine to help slow down from high speeds like that (so that the cop couldnt see my brakelights) quite afew times. i think you will be ok, you may for a pieceof mind want to have it checked out though
New Life
"Your Acura is equipped with disc brakes at all four wheels. A power assist helps reduce the effort needed on the brake pedal. The ABS helps you retain steering control when braking very hard."
This is a quote from the manual, now if 2003TLSnKc can find in any book or manual that this is different then I will stand corrected, 'til then, have a little respect when you talk to people or you may need to go back to high school where this kind of talk takes place.
Take a little of your own advice about talking to people with respect. The information is indeed correct. There is a drum system on the rear wheels only that is used only during application of the ebrake. The disc system is used during normal braking. It is you who wrongly accused us of spreading misinformation. Instead of accusing us, you should ask questions first. You won't look like such an idiot in the future.
Honda+Blue=My garage
I would like to know how to use the ebrake to slow down also.
You have to completely depress it to release, so how do you partially engage and then disengage without a full application?
Guys, you don't need to fully engage the ebrake to disengage it. Go to your cars and lightly tap the ebrake. Then hit it again to disengage. You don't need to fully depress it to disenage it. fsttyms1 isn't pulling your legs or anything, I have done it a couple of times. Just make sure you don't lead foot the ebrake else the car's ass will drift and you'll be fuked. It's still a big pain to use then my Accord's hand ebrake.
What a great way to end a discussion with an idiot.
Maybe he, maxx96, now think that the helm pages that Iggy attached isn't for the TL
or even better, the Helm pages are wrong.
Re: Re: i made a HUGE mistake, is my car ok??
Sometimes we just don't pay attention to that little light, special when we are in a hurry. What make it even worse is that the ebrake handle/pedal isn't locate where you can see it and get in the way of your shifting. I've been driving my SC300 and the Celica stickshift fulltime and I still forgot to disengage the TL twice, but only for like a second or so when i realized i wasn't moving. And Yes Maxx96, I checked my SC300 for the last few years, it also have drum e-brake and is a stickshift ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Back on the OP topics, probably no major damage to the braking system and/or rear axle, but you should check it anyway for safety sake and change the brake shoes. The warping you might have to wait to know
Originally posted by hzm82
bro is your "BRAKE" light out or something???? You don't see that RED light on the gauge? If you took it to 90 mph, I'm sure you only had it depressed to one or two clicks. I would still have it checked out.
New Life
Originally posted by Z Factor
Gentleman,
Let us stay on topic, and refrain from the personal attacks please.
Gentleman,
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
This is why I said what I said about our cars having 4 disc brake and I figured that when you apply the parking brake the rear pads came into contact with the disc thus applying the brake.
I always give good advice and research my input before I present it to the person asking the question, this is why I get mad when I hear that the wrong info is passed down, in this case I was not aware of this particular piece of information.
With all this said, and for those who flame me, I know now who you are and how you are and more important the rest of the forum knows who you are and how you are so good luck to you getting respect from the rest of the true TL family, as far as I'm concern, I'm not going to lower my self to your level.
Originally posted by MikeTL-S
THANK YOU IGGY and Hzm82.
I beleive about the ebrake and only partially stepping on it. I want to do that, just not sure how. Thanks for the info.
its not a all or nothing brake either. the more you push on it the more it grabs. just dont slam it to the floor while moving or you will lock up the rear tires
MAXX96- let me get this straight, you appologize for giving out misinformation, then you make it out to be others who were flaming people? You started this whole thing by chastising another member about stating wrong facts, then saying , " Im going to return my car if this is true...blah blah blah..." So if blaming others for you own faults makes you feel better, then go ahead and do it then.
After looking at the break down of the disc and parking brake assembly, I stand corrected as I didn't know that there was an inner portion within the disc that our cars use for parking brake.
If you get mad at misinformation, then you should be mad at yourself right now huh? Everyone flamed at you not because you were WRONG. It was because you kept on being thick headed and not listening to what they had to say. If you wanted respect, give it first. I bet you didn't even read what everyone had to say. Because it seems to me you were arguing against all the forum members who responded in this thread.
Originally posted by vicman17
Peace Folks!
Dunno nothin' about this disc, drum fiasco so I'm just gonna have a Coke and a smile and shut the f**k up!...
Peace Folks!
