I have a strange radiator problem
Old 08-22-2003, 07:36 AM
FidizzyTypeS's Avatar
Last night when I turned off my car the radiator fan would kick on. When I turn the car on it turned off. It stayed like that for about 10mins and then turned off. Has anyone heard of that? I did a search and found it on a 1st gen TL. But not on a second Gen. I have an 03 TL-S.
and yes i've had cars before that do that. But i've had my TL over a year now and that was the first time It's ever done that.
Old 08-22-2003, 10:06 AM
Bada Bing
SlyTLS's Avatar
Was it a really hot day? Did you run the motor hard? Was the AC on? It could be that the engine temp was higher than normal therefore it ran longer than usual.
Old 08-22-2003, 10:08 AM
i drove my car to florida at the weather was a constant 95-100 degrees. It never did that.
Last night was like 85 and i drove for 6 miles. nothing special.
Old 08-22-2003, 10:25 AM
'99 Acura 3.2TL
@cUr@-TL's Avatar
i think this is normal.. it happens to me sometimes.. when the engine is too hot
@cUr@-TL
Old 08-22-2003, 04:59 PM
yield2s's Avatar
that has never happened to me, it doesnt sound right. Mine will shut off with the key off and then turn right back on when i turn the key on if the temp is still high enough to need it on.
Old 08-22-2003, 05:08 PM
Dr. TLS
My old Hondas do this (or used to do this). It would run the fan for 10 mins after I shut down the car on a hot day. It happened in my 86 Prelude and also happens in my 96 Accord.
Old 08-22-2003, 05:16 PM
yield2s's Avatar
thats great. I think most of us have owned other car and some can remember there unique paterns,but what would really help is if member post what they've noticed their TL doin.
So far there are 2 informitive posts and they contradict each other,so let help get this figured out.
Peace
Old 08-22-2003, 06:12 PM
RACINGHART03's Avatar
OK. Here's the short short version. Engine coolant temp greater than 219 degrees f and the ignition switch hits lock... the radiator fan control module will energize the radiator fan relay for about 15 minutes. Hope that answers your questions.
Old 08-23-2003, 02:40 AM
well its still doing it. I called acura and they assured me that its normal. It is excessively hot here so i'm going to let the weekend pass and see what happens.
Old 08-23-2003, 03:03 AM
vtecbiggie's Avatar
It got up to 112 deg F a couple of days ago here (thats really hot for Canada) and mine was doing the same thing. It seems to do it more with city driving. Mine usually doesn't do it , but with it being such a hot summer it seems to do it more often. I think its normal.......
Cheers
Old 08-23-2003, 05:42 AM
AcuraTLFan's Avatar
Live in So.Cal. never had this happen to me. My friends Jetta will always run after you turn it off. Always, no matter warm or hot. Never knew honda/acuras do it too.
Old 08-23-2003, 10:06 AM
yield2s's Avatar
ya like i said earlier, mine has never done that. If i turn the car off while the fans are in use ,they turn off also, and then when i turn the car back on the fans turn on again( if the temp hasnt dropped enough while the car was parked) prehaps there are two differant critacle temps here, one being when the fans will turn on with engine on and a higher temp setting when the fans will stay on w/ engine off.
If that is the case you should really find out why your engine is getting that hot. is the temp gauge ever going above halfway? mine has never and that includes 110* dessert drives.
I just read the 1st post again and that is NOT right,why did the fans turn off when the key was on? if the engine was hot enough to require the fans to kick on with the key off,(cooling the engine to prevent damage)then why not with the key on?
but to get it all in perspective, if the cars not running hot(passed mid-point) then you should be fine. I accually was more worried about my system because since day one my fans will not stay on when i turn the key off. I was imagining my engine just sitting there cooking.
SidhuSaaB
05-30-2020 12:40 AM
12vancover
10-16-2015 12:04 PM
Matthew Purpura
09-25-2015 06:10 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
MikeJM310
09-24-2015 07:24 PM
Quick Reply: I have a strange radiator problem
