Humming/wind noise while driving
i have a problem. while i'm driving at about 30 mph, there seems to be a "humming" noise. as you get faster to 60ish - it's louder. but you go past 80 mph - the noise is gone.
it seems to be coming from the tires or something (sounds like coming from the back.)
since i had a wheel hub replaced a while ago, i thought it might be that since the noise sounded familar. but i did the "test" that my mechanic taught me - where you zig-zag left and right to put more weight on the bad hub, the more noise there should be, and where there's less weight = less noise. but the noise was constant... so i'm guessing a bad wheel hub is out. what else could it be?
it's like a "humming/wind" noise... i know it wasn't there before.. atleast i think..
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
oh, found a mistake. when i say hub, i mean bearing. "Wheel Bearing" - that was what was replaced awhile ago, and i tried to see if it's that.
its it a hum or a weird whistle? my car whistled and i thought i had a bad ground wire or something turns out the whistling is my tranny screaming for help and its getting replaced this week
Originally Posted by kabota
im thinking the bearings did not get packed right, enough Grease?? maybe
this was fixed awhile ago. i'm only mentioning it b/c the sound sounds familiar to a bad wheel bearing.
anybody, help? it's sounds like it's coming from the tires, like they are worn down or something. but it can't be, just got the falkens 512 about 5 months ago
Originally Posted by Fossil_TL
buy a Lexus. Super Quiet. But com'on the acura TL i drive already make me sleepy, some noise is actually good. plus wind noise is normal
wind noise near the door is normal, the humming noise i have now, is def. not normal. if you ride in my car, the first thing you will say is "man, what's wrong, what's that noise, why is it so loud?" everyone says that , that rides in my car. which is one of the reasons why it bothers me even more. the TL is a great car/ sweet ride. this noise makes it seem like a camery. (no offense - just contrasting the difference in class)
