How would this look on 3rd GEN?
13.2@ 107 on Street tires
http://www.evasivemotorsports.com/me...ode=FAB-485020
Ive been looking for a rear diffuser, this may work.
T-Swzy
A diffuser, in an automotive context, is a shaped section of the car underbody which improves the car's aerodynamic properties by enhancing the transition between the high-velocity airflow underneath the car and the much slower freestream airflow of the ambient atmosphere. It works by providing a space for the underbody airflow to decelerate and expand so that the boundary between the car's airflow and "external" airflow is less turbulent. It also provides a degree of "wake infill" (the wake being a turbulent area of low pressure that is caused by the passage of the vehicle through the air; this can cause pressure drag).
It works to bring the low pressure air below the car back to the ambient atmospheric pressure without inducing turbulence. It uses Bernoulli's principle, such that the pressure increases while the velocity decreases. Since the pressure below the car is lower than on the side and above the car, downforce is produced if implemented correctly.
basically it's a whole lotta math. creates downforce and regulates turbulance of air coming out from underneath the car
What your problem is?
Looks like Thomas (<-- that's me) is going to head to the hardware store this weekend... doesn't look to hard to build....
Will post the DIY after it is finished....
mlody
12-04-2019 02:11 PM
emailnatec
29
09-28-2018 04:27 PM
