How to use clay bar
Old Feb 25, 2002 | 07:15 AM
Pawel's Avatar
How to use clay bar
Ok guys, I'm realy not happy witht he way my car finish looks, so as soon as gets warm I will detailed it. So, I know I have to use the clay bar but I never used it before. Can someone tell me exactly how to use clay bar. And by the way, which company makes good brand.?
Old Feb 25, 2002 | 08:21 AM
NSXNEXT's Avatar
From the Zaino Web Site
How you should use Z-18 ClayBar?
First you should thoroughly wash the vehicle to make sure that there is no dirt or debris on the paint finish. Although Z-18 ClayBar is not abrasive to the paint finish, if dirt or debris is present on the paint finish, scratches could result when Z-18 ClayBar is rubbed over a dirty surface. Using a dishwashing detergent such as Liquid Dawn diluted with water will make sure
that the vehicle is free from grease, wax and oily film. (Mix 1 ounce of Liquid Dawn to 2.5 gallons of water for an effective cleaning solution)
Z-18 ClayBar should never be used on a hot surface or in direct sunlight. Using on a hot surface could cause Z-18 ClayBar to stick or "track" on the finish, however this can be removed by simply re-lubricating the surface and rubbing Z-18 ClayBar over the area again.
Z-18 ClayBar is designed to be used with a lubricant. The lubricant creates a "slick" surface for Z-18 ClayBar to glide across. In a spray bottle, mix ½ a cap of Z-7 Car Wash to 16 ounces of water for a lubricant. (You can also mix Z-7 Car Wash in a bucked and lubricate the section with a sponge.)
Lubricate a small section of the vehicle to be cleaned (approximately a 3-ft x 3-ft area). Using adequate pressure, begin rubbing Z-18 ClayBar over the lubricated section to remove contaminants. You can actually feel the contaminants being removed and as the section becomes smooth, simply wipe the area with a 100% cotton towel and continue in small sections until the entire vehicle is complete.
As one side of Z-18 ClayBar becomes soiled, simply flip to the other clean side. After both sides have been used, pull, stretch and refold Z-18 ClayBar to expose a fresh clean side. When pulling, stretching and folding no longer exposes a clean side, discard and use a new piece. Note: Occasionally inspect Z-18 ClayBar to make sure there is no heavy dirt or debris present.
Re-wash the entire vehicle with Z-7 Car Wash if you are planning on applying Z-1, Z-2 or Z-5 immediately after the Clay Cleaning Process.
**Important note: Avoid reusing Z-18 ClayBar if it has been dropped on the ground. If dropped on the ground it may pick up dirt, or other debris that can cause serious scratches to the paint finish.
Should I protect the finish after using Z-18 ClayBar?
After using Z-18 ClayBar, the finish has been truly cleaned of all contaminants and stripped of all wax and/or polish leaving it vulnerable to the suns UV rays, acid rain and other elements. The finish should now be protected with wax, polish and or paint sealant to protect the quality and longevity of the finish.
For ultimate shine and protection, use Zaino Bros Show Car Polish. Zaino Bros Show Car Polish is easy to use and provides the ultimate "wet-look" shine with the strongest and most durable protection in the industry.
Old Feb 25, 2002 | 08:33 AM
BlackShadow's Avatar
O.G.
Neil, you really need professional help.
BTW, I am calling you when I plan to detail my TL.:p
Old Feb 25, 2002 | 08:47 AM
NSXNEXT's Avatar
No problem. And yes I do need help. Wanna help me put another coat of Z2 on the car today?
Old Feb 25, 2002 | 11:01 AM
O.G.
Sure I'll help you put a coat of Z2 on.....only if you put on 3 coats of everything on my TL first.
Old Feb 25, 2002 | 11:55 AM
Pawel's Avatar
Got better idea... Neil and I will supply the products whiule you Binh will supply the manual labor.
Thanks Neil. I guess I will have to clay bar my whole car. I goot alot small "orange bumps" on my finish. Damn, there goes nice warm weekend....
Old Feb 25, 2002 | 11:56 AM
O.G.
Neil and Pawel, are you guys coming to the March 24th meet at South Mountain Arena in West Orange, NJ?
Old Feb 25, 2002 | 12:12 PM
Crzy Acura's Avatar
wow man, thanks soo much for the write up!! :wow:
Old Feb 25, 2002 | 12:29 PM
NSXNEXT's Avatar
Pretty sure I'm coming. You know...the wife needs to approve my travel plans.
Old Feb 25, 2002 | 01:09 PM
O.G.
Mine got approved already.
BTW, are you bringing her?
Old Feb 25, 2002 | 01:26 PM
daverman's Avatar
Unfortunately claying will not remove the orange peel bumps. It'll only remove the "roughness" out of your paint.
Old Feb 25, 2002 | 01:48 PM
NSXNEXT's Avatar
Time to color sand your car. And no please don't ask me how to do it. Way too much liability in that.
Old Feb 25, 2002 | 04:13 PM
Pawel's Avatar
Yeah, I'm planning to show up. And yes, it would be cool if Joey, and you Binh could meet at his house and drive together like always....
tsx_boy
Dec 13, 2019 08:33 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hashbrown
Sep 29, 2015 12:13 PM
