How To Remove Wood From Door Trim
Does Any One Know how To remove the wood off the door Panel
I Know How To Take The Door Panel Off But I cant seem to get the wood off the door...
Help
Help
Received 1,080 Likes
Well first question is WHY? What are you planning to do?
Second, it's a b!tch to do. You have to melt the plastic rivets to get the trim pieces off. And if you screw it up, you're screwed cause you can't buy those pieces. You have to buy the whole door panel.
Good luck.
Good luck.
Re: How To Remove Wood From Door Trim
Help
Help
It wasn't designed to come off. Acura sells the whole door panel as one unit, wood and all. It's not a separate piece--you have to buy the whole panel if you need a replacement. So if you take it off you're doing something it was not meant to do. Meaning you're going to have to either drill out fasteners or melt them.
Retired MOD
1 Post
Re: Re: How To Remove Wood From Door Trim
Originally posted by BLEXV6
Check out the faq section. Snook I believe, changed the door inserts, and he provided a step by step instruction that looked like a real PIA.
I together with Tim did the ones on his car.
Like NSXNEXT said, you have to melt the rivets then take it off. After you have done all four and done whatever you want with them, you have to melt the rivets again to put it back.
Good luck.
09-17-2015 09:01 PM
