How to remove TPS
Why do you want to remove it.
Its not meant to be removed. Its held on with rivets. You will have to carefully drill them out to remove it. BUT you will need a multi meter and the specs to reinstall it so that the car runs normal.
Received 1,080 Likes
Take a dremel and cut slots into the rivets. They are actually screws that had the heads cut off.
Cut a deep enough slot to get a small flat head screwdriver into. Lefty loosy and you're done.
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
