How often do you guys do your oil and tranny fluid change?
Just wondering. I have a 99 and use Mobil1 5w 30. And Honda ATF for tranny fluid? Is there an oil you guys prefer for your Motor?
Depends on how Often you drive the Car but in my Case and the Amount of Miles I do every Month I:
Change the Engine Oil every 6 Months with Mobil 1 Synthetic "EP" 5W-30
Why EP? well it Covers 15,000K or 1 Year so if For any Reason I cant change my Oil at 6 Months I have the Piece of Mind that My Engine is Protected Anyways... The Filter I use is K&N HP-1004...
With ATF I use Honda DW-1 on a Yearly Basis and this is Becouse Mileage and The Problem with our Trans. I add a Magnefine External Filter Too.
This topic has been
You may want to search for this as there a ton of long threads. May save you time instead of waiting for others to reply. I see you're new so don't take that the wrong way
any oil and filter is fine
5w 30 for most of us all year,,cold weather people see threads
the oil change reminder light is set to stay on at 7500
atf: honda DW1 once a year do a single drain and fill of 3.4 qts
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
HeloDown
09-08-2015 06:51 PM
