How often do we have to replace the fuel filter?
I'm just curious as to how often we have to replace the fuel filter and how hard it is to do.
Rosh
Rosh
I can't find one either... Someone said it might solve my low idling problem... How do you know if you have carbon buildup in your engine? Is there some way to look and see?
Instructions for fuel filter.
I Hope this helps.....
Fuel Filter Removal & Installation (3.2TL)
Fuel Filter is located in fuel tank, attached to fuel pump. Release fuel system pressure, Remove Fuel Pump, Remove fuel filter from fuel pump. To install, reverse removal procedure.
Removal of Fuel Pump. (3.2TL)
Disconnect negative battery cable. Remove spare tire compartment lid. Remove access panel from floor, Disconnect fuel pump 5-pin connector. Remove fuel fill cap. Release fuel pressure. Disconnect quick-connect fittings from fuel pump. Remove 8 fuel pump assembly bolts. Lift out fuel pump assembly.
FUEL PRESSURE RELEASE
Always relieve fuel pressure before disconnecting any fuel injection-related component. DO NOT allow fuel to contact engine or electrical components.
Disconnect negative battery cable. Remove fuel filler cap. Place shop rags around fuel pulsation damper ( located on top of fuel rail. ) Slowly loosen damper one complete turn. Fuel pressure is now released. After repairs are complete, remove fuel pulsation damper and install NEW washers. Tighten damper to 16ft lbs. (22 N.m.)
Information supplied by Mitchell On-Demand System.
That might be the aux. fuel filter in the tank, there could be one under the hood, usually next to the firewall for Honda. I had that changed for my last Accord. Not sure if the TL has it, will check service manual.
i have a newer BMW motorcycle and the fuel filter is actually inside the gas tank attached to the fuel pump. so it is possible the TL's is in the tank. And since i cant find anyone who makes one aftermarket (like K&N or Fram) i assume this is correct.
If there is a lot of carbon buildup it will cause preignition.
Not unless something is wrong with it, its in the tank.
I'm also told that it's not replaced until it's the suspect of a problem and/or is the thing causing a problem.
Chad05TL (07-14-2019)
Its MUCH better that he bumped an old thread and re-asked the question here than another thread. Every one keeps telling people to "search" thats what he did. Now your bashing him for doing it ???
There's no Acura in
I will say that it varies from forum to forum.
Some tell you:
1) Don't resurrect old ass threads; make a new one
while others say
2) Search & don't create new threads
It seems #2 applies on this forum. The ironic thing is that when you search, threads are listed by relevance as opposed to date. So by default you resurrect old threads...which confirms #2.
The problem I have is that some key threads get super long (ex: Tranny Failure & Seafoam DIY)...and finding the info you need can be harder than creating a new thread & getting a definite answer in less than 5 or so replies (but with information based upon old-ass threads).
'Cause I mean how are you 'searching' if you're going through 40 pages of replies for a single thread?
I don't really have a problem with it & am not expecting any changes in the forum "rules", but that's just something that's been on my mind since I joined last week. Older members have an advantage over us new ones because they absorb information without having an actual specific need, while us new people come and are already looking for a certain piece of info.
Some tell you:
while others say
I wouldnt exactly call this being helpful, or a constructive post. Why post this? He did what most would tell him to do if he posted the question. Why is it a big deal for him to bring an old thread up and post a question that relates to it in it??
Can we get a DIY with pics for the fuel filter?
Smitty and civicking had pics up in 2005, by they are now red X'd.
civics were straight out of the HondAc manual:
https://acurazine.com/forums/2g-cl-2001-2003-50/fuel-filter-468470/
Smitty or civicking or anyone, can you ressurect pics?
Can anyone changing theirs view the filter to see if it was dirty or not?
Another posts: don't jump thru hoops changing fuel filter and pump when all it might be is a loose trunk wire:
https://acurazine.com/forums/2g-tl-1999-2003-98/fuel-filter-fuel-pump-635946/
https://acurazine.com/forums/showthread.php?t=468470
https://acurazine.com/forums/showthread.php?t=635946
nanos
11-12-2015 08:41 PM
NBP_BALLER
09-23-2015 08:18 PM
Skirmich
09-15-2015 06:41 PM
