how much power to the wheels? (TL-P)
according to dynolicious i put about ~160 horses to the wheels, which is pretty disappointing to me, although the vehicle is bone stock. however i found this graph for 1999 TL-P allegedly stock, but numbers seem to be a bit too high?
thats probably at the crank not the wheels- you lose 20 percent in numbers right there
Plus a ~fresh~ motor vs 150kms on yours?
little things like lightweight engine oil will give improved numbers `for testing`
look what they do to come up with CAFE fuel numbers!!
perfect valve adjustment on yours?
brand new spark plugs and seafoam the gas and intake methods, plus engine oil method before the oil change = all improve combustion = better torque or allow freer operation = less drag = more power available to measure
hp reading is all a head game, if you want a faster TL- install a lightweight crank pulley
By shedding 8 of 10 pounds off the end of the crankshaft the engine revs much quiker-getting you to vtec and the real power that much faster
Caution -heavy foot = loss of fuel economy..you play you pay
Unregistered Member
Something is off with your car. 160hp to the wheels is too low. Then again, the dynolicious app isn't the best way to test your car. I used that same app when my car was stock + CAI, and I was getting ~180whp. I'm also a TL-P.
Maybe try some SeaFoam in Oil and Gas. Get your valves adjusted too, though I have yet to do mine.
Because its a phone app and not directly measuring the output at the wheels.
justnspace (08-09-2011)
Unregistered Member
190 is pretty high for a 10 year old car, but I agree that 160 is too low.
The app is really meant to measure your 0-60, and other times. How fast was your 0-60? It can be tough to find a empty road long enough for the full test.
so I make numbers up out of thin air~ the theory is correct~
those are also `corrected numbers` which means it wasnt 59 degrees and sea level- the testing standard
so everything must be a calculation
Lead Footed
Just think of the poor TypeS guys that have a 260hp car and at the dynos only put down 196-201 or more than 20% lost through the drive train . . FWD automatics are the worst.
Ruf
ok i think i should give more info about my vehicle. my car is bone stock. it has 90,000km or 60k miles on it. i recently did a service including changed tranny fluid, seafoam, fuel injector cleaning, new tires, new filter and had the whole car inspected (exhausts, catalystic conv, balljoints, mounts etc). The dynolicous app i use is relatively accurate with my other vehicles reporting 211hp for my rdx and 265hp for my 135i. for the TL i get 158 to 160 horses consistently. 0-60 was around 7.5 with gate shifting 8 just left in D with TC on.
Unregistered Member
If you're 0-60 is 7.5 seconds, then your fine. You're not putting in the correct weight of the car. I just put in the weight of the car (without my weight) and I got ~184whp for ~7.5 seconds.
Your telling the app that your car's weight is lighter than it really is.
however i do put in the correct weight. 3635lbs.
Those times are kinda slow for a TL-P Best time i got with mine was a high 14 with nothing more than comptech axle backs and a K&N drop in. That was with near 180k miles on the odo.
ok so i ran out tonight and did a 1/4 mile test. the humidity was unusally high tonight 80% so that might hurt a bit. but it was a definite improvement with gateshifting to 6500 rpm:
note that with gateshifting 2nd gear falls into vtec so its smoother. you can also tell by bigger shiftpoint spikes that its gateshifted. i figure with header & intake mod it'll be 180hp territory.
Lead Footed
I'm sure you heard this, but get your 60' time down. If I'm partially correct, if you aren't getting good results on you runs these sort of apps will calculate based on the results which won't reflect your true dyno results. So with that, I'm betting that if you went to a shop and did some dyno test you'd end up with a better result.
BTW, I'm not sure what the yellow curve is, but it looks a bit funky once what would be VTEC range kicks in.
Ruf
Ruf
Ruf
Ruf
Lead Footed
are you talking about the first run or second (gate shifting)? i was worried before with 16.2s 1/4 mi and 8s 0-60, because according to other websites 0-60 7.4 and 1/4 mi of 15.7 is dead on for a TL-P. as for 60' i have no idea how to improve that, i am on brand new tires. but i am happy with my 2nd run.
Not sure what a TL-P does in the 60', but 2.72 sec seems a bit slow. I would have expected something in the 2.4 range, but not really up on them. How are you launching the car? Such as are you bring up the RPM before you take off? How much tire spin are you having?
As for the runs, I just noticed something. Is the yellow line showing the shift points. I've never really looked at this dyno while you drive results. In regard to shifting, gate shifting will produce the best time.
Ruf
In any case though, this is a mobile app so it's limited by the inaccuracy of the accelerometer and/or gps (depending which is used). I wouldn't get too caught up in troubleshooting low numbers without a real dyno run.
Never dynoed the TL-P motor
Now? not sure, motor is getting a little old, but With the current motor when it was dyno'ed shortly after the 6 speed swap i was around 286 at the wheels (last 1/4 was something 13.46 @ like 104.6). The new motor im putting in im hoping to be in the 310whp range (if and when i ever get it finished (note to those not married, stay that way
Im hoping for a nice increase in TQ with the new motor which will really help things. If i can ever get around to affording a new light weight flywheel combined with the lightened crank and crank pulley i will have removed almost 40 lbs of rotational mass motor is going to scream. gotta get the 80 mm tb yet and intake mani modified to fit it along with pistons
sorry
sorry
3.2 block, 3.5 crank, still deciding on RL pistons or the slightly less compression TL-S pistons. Also trying to decide on if i send the block back for the OE slightly oversized pistons Still deciding if i want boost or not either
Lead Footed
sorry
sorry
yes . . need more TQ . . . some day, if I keep the car that long I plan on a 3.5 build and doing some machine work to reduce/improve rotational mass. Even with an auto it should run mid 13s.
Ruf
Yes TCS was on now that i think about im not sure why i forgot to turn it off that's probably why 60' is bad. I did torque launch and there was wheelspin, the TCS controlled the spin. I get lots of wheelspin without TCS from standstill if i remember correctly, all the way to ~30mph. so should i do one without TCS even though ill get lots of wheelspin? Weather was 18'c with 80% humidity, relatively new flat asphalt. I think it's the launch that's hurting my time. but my 30-90 times of 12.45s actually beats stock BMW 328i numbers from dynolicious users.
Anyway i got my car on a dynojet this morning and putdown 173hp at 6000rpm and 166 ft-lb at 3800 rpm. According to their records a 2002 TL-S pulled 200hp at the wheels just last month so thats about 23% drivetrain loss. 225x.077=173. seems my number is ok. i'm not sure why dynolicious is displaying too low, its right on for my other cars. For the RDX it displayed 210 stock and 220 with ecu flash, very close to hondata testing #s.
