how much HP can i increase on my 2001TL
how much HP can i increase on my 2001TL...??
without SuperCharger~~~~~~~
thanks~~~~~
also what kind of stuff should i need to buy ???
thanks~~~~~
Well here are the options you can other then the SC kit.
1. 3.5 conversion - similar to getting a SC kit, and I don't think it's worth it...
2. Intake
3. Header
4. Exthust
5. Pulley
6. spark plugs
2. Intake
3. Header
4. Exthust
5. Pulley
6. spark plugs
2. Intake
3. Header
4. Exthust
5. Pulley
6. spark plugs
2. Intake
3. Header
4. Exthust
5. Pulley
6. spark plugs
8. and the NEW mystery Mod...just posted today
9. Higher octane gas will help also...
10. NOS (I wouldn't go there)
well I don't like the way the introduce the M. mod. Trying to create maketing hype... that's all I see here...
hum... you can get the VTEC controller as well... BTW
Scottie here are my best guesses to your question based on dyno runs I have seen. These figures are for a TL at redline: Intake: 6 Mufflers: 5 Headers: 22 Pulleys: 3 Plugs: 0 REM:12 There should also be gains from removing the resonator, maybe 5? The reason I said spark plugs zero is because new plugs should add back alittle lost power over the old ones, but I've never seen proof that they add power, but that could be debatable. Grand total above: 53. So 225 stock plus 53 is 278 at the crankshaft, not too bad if I'm anywhere near close.
What intake and what mufflers are you referring to? Also, sorry for the lack of knowledge, what is REM?
The intake i'm referring to is the AEM brand ( or Injen ) cold air intake setup; the mufflers can be Comptech or any brand flow thru mufflers. Check some posts for pics of guys cars and check also for the REM posts - it's like a box or chamber that will bolt right on to our intake manifolds and looks to be a real performer adding from 8 to 16 HP at the wheels.
09-17-2015 09:01 PM
