how much for the 100,000 mile service?
I was just quoted 1300 at the dealer including pulleys and waterpump.
parts included of course. How much should this cost. The only reason I would consider the dealer was the recent post regarding position of the pulleys versus the belt. can I go wrong with attempting to have my backyard mechanic do this for me? YOM (your oppinion matters) |
It seems a bit expensive, but certainly not anything absurd. It is a dealership after all. I had my car serviced by a backyard mechanic, and I had no complaints. However, I would recommend you ensure that your PS belt is properly tightened. If it is overtightened (very likely), then it will pull the PS pulley down. This will eventually allow air to enter the system, and you will probably have to replace parts.
Either way, anyone with any Honda/Acura experience should be able to perform a timing belt job just fine. There's even a DIY for it. |
what post on pulley position are you referring to?
some 03 had an OE problem but those were done under recall the 105 service runs 800-1500,,range from private shop to dealer just the parts run 250-400! joes tree garage may not be able to remove the big nut with 132 ft lbs torque or get it back on correct tightness/torque see the many 105 service threads for more info |
Just question your mechanic first to see if he has previous Honda experience. Maybe get some references from other Honda owners for which he has done work. Good luck.
I agree- past experience on hondas or better yet a TL-is a must
those guys know about the ps tensioner setting, too tight ruins the pump To know where the hidden bolts are beats looking at the diy as you go~ and speeds the process greatly look at the diy and you will understand |
I got mine done for $350.00 by a Certified Acura Master tech out of his private garage...he only did the timing belt and water pump though. If anyone is in the Philadelphia area, pm me and I'll get you his info. I highly recommend him, he's very knowledgeable about these 3rd gens, he owns one himself!
I also recently had him do 2 front rotors, all 4 pads, flush and fill, plugs and oil change last week all for $350....that includes all the parts except the plugs and the oil, I bought them myself. |
My usual local shop did the timing belt/water pump service, $900 - incld. alignment & tire rotation
that sounds about right, Got mine done at Mcchurchill acura in tx and cost me 1200 bucks. they even made it sound like a great deal by throwing in a cabin filter (LOL) It just gives me a better piece of mind to know it was done there and i dont have to worry about it for another 100k especially our engines with such close tolerences
I worry on any job done without new tensioners and idler pully
cant expect them to last another 105- is my opinion One of those fails,,, and its a broken timing belt scenario |
Don't say that- it might curse mine. :behead:
Originally Posted by 01tl4tl
(Post 12687686)
except when the grease runs out or the the bearing gives up~
Plenty of pics on here to prove we are lucky to get 105!! totld- I can say what I want in generic terms,,as long as you dont claim excellence in,,, then all should be well for you |
The price greatly varies depending on where you go. I paid $450 for parts and labor for water pump, timing belt, power steering belt, alternator belt, coolant, NGK Iridium spark plugs, oil seals, idler pully, side engine mount, and installing rear brake pads (I already had the pads so only needed the labor). I purchased the parts online from an Acura dealer and everything ran about $250 and the labor was about $200. All parts were OEM other than the spark plugs. I didn't do the adjusters since my mechanic said he hasn't really ever had a problem on them and he has been working on my family's cars for over 15 years alone. The same service probably would have run about $1500 at the dealership. The best advice is to shop around but make sure the place has experience doing this work on Hondas because it makes a difference.
apar83, where are you located? think that I could get the same deal?
Originally Posted by apar83
(Post 12701008)
Originally Posted by darkdeuce
(Post 12702674)
every once in a while, honda dealers run timing belt specials for $500, parts included..have to keep an eye out for them though..they don't really advertise it
I got a honda tech to do mine at the dealership for 550 with parts. Belts, pump and pulleys.
+1 for Honda dealerships
thanks
