How hard is it to remove door panel?
hi, im installing some phoenix gold components and i wanted to know how hard it was to remove the door panel. do you need special tools?
Originally Posted by youngBuk
can someone gib me a link on how to remove it
Removing door covers
All doors are pretty much the same, except the driver's door has more wire harnesses to
unplug.
Start by removing the big screw in the armrest, then the little screw behind a little round
cover behind the inside door release. slide the door release mechanism back about 3/8"
and pull out. There's a little plastic catch on the metal bar--unhook it and remove the
assembly.
The door cover is held on by plastic friction clips. They're pretty forgiving of being pulled
up without the proper tool. (Buy the tool though--it'll come in handy).
Remove the sail panels (black triangular plastic at front of front door windows) before
pulling up the front door covers. The sail panels pull out from the back (towards rear of
car), then slide back to free the front corner.
That's it--just unfasten the harnesses/lights and it's out.
handsom-hustla
11-13-2015 05:04 PM
