How far can we go on the "orange gas light"??
I am always shocked when I fill up after the orange light has been on for a while and it take less than 15 Gallons to fill up. Has anybody experimented to see how far we can go on the orange light?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
funny you should make this post. my light came on yesterday, i filled up 14.7 gallons.
then I read somewhere we have a 17 + gallon tank.
I hate filling up, so at least now I now it's a premature-e-gauge-alator.
ChairmanMaoSaysRTFM
Originally posted by pej7445
what does "floating gas tank" mean?
FYI: I have an 03 TL-S NAVI
im not sure on the definition of a "floating tank" though. am i right or wrong here Darkshear?
SSTS
If I drive conservatively when the light goes on I get a reliable
50 miles out of reserve. I don't think taking a hrd turn would kill
you (unless is was a very long hard one) but when near the very
end of the reserve you probably want to avoid steep hills.
I once backed up my old 87 Camry onto a steep incline at a bridge and stalled it out because I was nearly outta fuel. I had to coast it down to flat and level to get it to start again to move it 100 feet to a fuel pump!
/Steve
/Steve
Originally posted by kennelm
The manual tells you that the gas tank holds 17.17 gallons.
This topic has been beat to death........but, I might as well add to it.
If you notice the gas light comes on very early, at about two hash marks before the empty mark. Each mark is about 20-30 miles worth of gas, depending on how you drive.
On top of that you still have about 2.2 - 2.8 gallons left in the tank when you get to the empty mark. So once the gas light turns on you should be able to get 60-90 miles until running completely out of gas.
What your problem is?
The most I have gotten is 60 miles, you have about 3 gallons left, so depending on how your driving, that could be anywhere from 60 to 80 miles. I am kinda an aggresive driver so I get the low end....
I was recently on a long trip and was getting over 32mpg. My light came on at 445 and I filled at 485. I took 15 gallons even (putting about $0.20 in after the first shutoff). So if I had a little over 2 gallons left, @32mpg you could theoretically get over 100.
I wouldn't have the guts to do it though.
spoiler900
10-10-2015 06:48 PM
