how do you rotate the tires?
do you put the rears on the front, and the fronts on the rear?
OR, do you put the right tires on the left side, then the rear to the front, and vice versa
are stock tires directional or non directional?
Most experts recommend the modified X method. Rotate both front wheels straight back and cross the rears to the front(rr goes to LF etc.) Eventually all tires will be in all locations.
I don't know if the OEM Michelins are directional - either call Acura, look at www.tirerack.com or take a gander at the tire to see if it says.
'01 pearlescent white
-Wing, tint, cop-finder
'88 White RX-7 Convertible
-Permanent tinitus courtesy of Rockford-Fosgate
definately go with the X. That's what my manual says to do. and that;s what they do at the dealership. but only if they are not directional....
1996 2.5 TL Dark Green
HKS Powerflow, HKS Fuel Pressure Regulator, Sebring Exhaust, Jacobs Pro Street, Apex-i AFC, Jet ECU, Powerslot Rotors, Axxis Metal Master Pads, PIAA 1100x, Clarion 9255, Tube Driver Amps, Boston Pro 10's (2) , CD Technologies 6-4-2, Clarion MVA6491 (3), Valentine 1, Cliford Avant Guard 4, Monster Capacitors (2), Jacobs Accuvolt, Trunk, Underdash and Underbody Neons
No nav yet but soon!!!
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
