How do you remove the wood grain pieces in the door panels??
Old 09-28-2007, 03:18 PM
99TL-p 114K
dvsxlt247's Avatar
Question How do you remove the wood grain pieces in the door panels??
Ive already done a search for this. Couldnt find what i was looking for.
I need to know how to remove the wood grain pieces in the door panels. Can someone help me out and please explain to me how to do this. Any pics would be appreciated very much.
Old 09-28-2007, 03:37 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
You have to remove the door panel and drill out teh plastic riviots that hold it in place.
Old 09-28-2007, 08:29 PM
99TL-p 114K
dvsxlt247's Avatar
So first, i drill out the plastic riviots that are holding the door panel in place, then i just pull the door panel off the door and pop out the wood grain pieces??? Im not quite sure i understand what your saying. So what happens after i drill out the plastic riviots? I cant put it back on now until i go to the dealer and buy new plastic riviots???? WHAT.
Old 09-28-2007, 10:49 PM
BAPE head's Avatar
i just did this a few weeks ago.
1. Remove the door panels, seach i the forums, it's not hard, it just time consuming.
2. Remove all wires plugged into the panel and take the panel off the door
3. Remove about 20 screws from each panel for the arm rest part to come off in each panel
4. Drill out each plastic rivit and be VERY CAREFUL not to go through the panel, it's very easy to do this.
5. Then do what you like with the wood grain, paint it, sand it, cover it, etc...
6. Since you drilled out the panels, you have to glue them back in place and then put your panels back togeather.
There is a DIY in the DIY section for repairing peeling panels. It's not hard, but it is very time consuming, working alone, took me about 2 hours to get each door panel off and dismantled and wood grain removed.
5.
Old 09-28-2007, 10:54 PM
BAPE head's Avatar
https://acurazine.com/forums/showthr...ght=door+panel
here you go, this is the one i followed, it's for a CL but it's pretty much the same...
Old 09-28-2007, 11:23 PM
wham bam thank you ma'am
Rajca's Avatar
5.
i did the same thing except for step 6 i found similar screws to the ones that hold on the arm rest and screwed them in and it hold just fine. but be careful not to go to deep into the wood grain
Old 09-29-2007, 12:09 AM
99TL-p 114K
dvsxlt247's Avatar
Yo good lookin. Thanks alot man, appreciate it. Its just that i didnt know there was so much work involved just to get the damn wood grain pieces out, shit lol. Will be doing this though. Well see what happens.
02-25-2020 09:57 AM
govtcheez
10-01-2015 12:21 AM
CadiGTi
09-14-2015 06:37 PM
oyayjoe
09-12-2015 04:40 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: How do you remove the wood grain pieces in the door panels??
