How do I program my remote??
I just bought a '99 TL. Love it but I only got one remote so picked one up off of ebay!!! I am sure that it is the right one for my car the numbers on the back match and it looks the same but I did not recieve any programming instructions!!! Can someone please tell me how I can program this???
Thanks,
Corinna
Thanks,
Corinna
I got instructions from the Acura dealer on how to program the remote.
-open the driver's door, press and HOLD the door unlock button...put the key in the ignition and take it out (repeat this 4 more times within 10 seconds).....the door lock/unlock should cycle now to show that you are in program mode. now press the unlock button on the remote and make sure it works...then put the key back in the ignition and make sure eveything works fine....
This is what I remember from the instructions....if it doesn't work I will find the actual paper and fax it to you if you want.
Hope that helps...
Derrick2533@yahoo.com
Hope that helps...
joflewbyu2
10-08-2015 11:16 AM
SinCityTLX
10-07-2015 01:24 PM
