how to change rear wheel bearings?
hello i searched all over i may have of missed it but does anyone know how to change a rear wheel bearing? im looking for a d.i.y. thanks any help is appreciated
Not really a DIY but you need to take off the rear rotor and axle nut. Once the nut is off the hub should slide off leaving the bearing. If the bearing is froze to the shaft use a chisel like in the link
https://acurazine.com/forums/showthr...hlight=bearing
