Homelink programming
Guest
Posts: n/a
I have a new generation garage door opener with those rotating security codes and I'm having problems programming the Homelink. I've followed the directions but it still doesn't seem to work. Any advice or clues would be helpful
Sticky Rice OwnZ joO
1 Post
You might have have to put the opener in training mode.. if you have the instructions for it, check it out...
once you have it in that mode, you should be able to program it...
just programmed mine the other day...
- train the button in your car
- go to opener and press the appropriate button until its LED starts blinking
- go back to car and press the same button
- when opener LED goes off then you are good to go!
joflewbyu2
10-08-2015 11:16 AM
