High Voltage Kits
I need 2 more gears
High Voltage Kits
Do the high voltage kit sold on autocarparts.com site really worth it? Has anyone done this and what happened. Did you get more power, better MPG or nothing at all?
I need 2 more gears
yeah the hyper voltage kit. So you don't think it really works. I kinda was more interested in it because of my subs. They are pulling 600watts rms right now and I will upgrade my amp sooner or later to 500watts rms to each sub.
Boomer SOONER
if you want something like that, you can make it yourself. Just go buy some 4 guage power wire from any car audio shop and you can cut to length the wires you need for not much money at all - and will acomplish the same thing, and I do believe it is worth it.
Though, 1000 watts RMS isnt going to need that much help - I have 1100+ RMS, and everything is just fine. The best thing would be to get an Optima Yellow top battery, and make those new ground wires yourself.
I need 2 more gears
i already have an optima redtop which is actually a stronger battery, but doesnt have the same regenerative capabilities the yellow top does. If all I need to 4 gauge wire then what is the box that comes with the hyper voltage kit do? Also is there really any performance gain to be had here? How is it installed BTW?
Boomer SOONER
The redtop is a good battery for everyday use, but for a big stereo, the yellow top is much better because of its deep cycle capabilities and the regenerative capabilities like you said.
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
09-15-2015 06:44 PM
HeloDown
09-08-2015 06:51 PM
