HELP: WW vs OEM rear lip
Alright, i have the front tl 99-01 front lip custom fitted on my 2nd gen cl, i have the OEM aero side skirts and rear lip as well that i'm going to custom fit in a few weeks and i need some help.
basically i can get the WW rear lip and was wondering for those who have it:
1. how's the quality? its poly urethane.... compairing it to oem
2. what exhaust modifications were needed to fit the exhaust
3. what size tip is recommended? i believe 3-3.5 inches look good with this kit.
4. is the exhaust cut out the same as the oem aero kit's cut out? (location wise, since oem is a smaller "indent"
thanks for the help
thanks for the help
i HAD the ww rear lip but never installed it, just test fitted. It's made of polyurethane so quality is not a problem. I dont think you'd need to make modifications to the exhaust to make it fit, it doesn't stick out more than oem, it's just thicker, hence the larger exhaust cutouts. When i test fitted the ww rear lip, i had the 3.5" 3A tips and they looked fine, not too small for the cutouts. lastly, the locations are pretty much the same, if i remember correctly. in any case, i'm sure the ww rear would look hot on the CL
benny_jdm
01-31-2016 06:15 AM
