Help! - Windshield Wipers Going Crazy
Old Oct 7, 2003 | 03:00 PM
mdavisii's Avatar
B93P TL Owner
Hello -
Is anyone experiencing an issue with their wipers where sometimes they "slam" down too far on the windshield (sounds very annoying afterwhile)? I had Acura take a look at this, and was informed that the "scissor assembly" is bad and would have to be replaced. Is this something I can do on my own, or is this something that needs to be left up to the professionals? From what I am told, this has been a problem for Second Generation TL models.
P.S. They did adjust the blades, but because there is so much play with this the effect is pretty much still the same.
Old Oct 7, 2003 | 03:52 PM
I was having the same problem. I am actually going to replace the part this weekend, but I have already taken apart things to find the defective part. It is really not that difficult, probably something you could do. If you done things like changing spark plugs, etc. on cars in the past then I would just do it yourself.
Old Oct 7, 2003 | 05:03 PM
mdavisii's Avatar
B93P TL Owner
Hey,
Would you mind telling me how to go about taking everything apart? I am assuming everything's behind the black strip the wiper arms rest on. And how much did you pay for this "scissor assembly" part? Thanks for the feedback!
Old Oct 7, 2003 | 05:45 PM
8th Gear
Out of curiosity, did your wipers also wipe to far across the windshield? Sometimes mine slam down on the cowl as you mentioned and other times they switch and the drivers side will slam into the a-pillar. It seems to get worse the faster I go. I even had it get stuck past the a-pillar once when I was on the highway.
Old Oct 8, 2003 | 08:23 AM
mdavisii's Avatar
B93P TL Owner
Yes my car experiences the exact same thing. The faster you go the worse it is (sometimes). Looks like you need that scissor assembly as well. It makes me wonder why there isn't a TSB on this issue if it is such a common problem as the dealer indicated.
Old Oct 8, 2003 | 11:55 AM
8th Gear
It would appear so. I'll try to call the dealer today to get a part number on that and let you know if emfrench hasn't responded by then...
Old Oct 8, 2003 | 12:24 PM
mdavisii's Avatar
B93P TL Owner
Thanks!
Old Oct 8, 2003 | 01:12 PM
nym31mp's Avatar
Rock Star
is it a dealerhsip thing that they can do under warrenty therefore u dont have 2 pay or it it something where u have 2 just replace the bad part w a better part.......peace
Old Oct 27, 2003 | 10:16 AM
mdavisii's Avatar
B93P TL Owner
Has anyone had any success with repairing the wiper assembly? Mine is getting to be unbearable and will probably look into repairing real soon. Thanks!
Old Feb 6, 2005 | 07:38 PM
Any luck on fixing this? Mines been doing it forever and it's really starting to get on my nerves.
Old Feb 6, 2005 | 08:51 PM
soccerbenk's Avatar
yews i just had this problem and fixed it it was a linkage arm thatr wears out the part cost $19 and i replaced it myself and now my wipers are fine
Old Feb 6, 2005 | 08:54 PM
Cool, thanks.
Old Feb 7, 2005 | 11:08 AM
mdavisii's Avatar
B93P TL Owner
I fixed this problem myself. Purchased a used transmission (scissor) assembly from the junkyard about a year ago. Haven't had a problem since.
TheMuffinMan
Jun 2, 2022 07:11 AM
bluetl04
Aug 16, 2016 02:49 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
merc009
Sep 29, 2015 03:06 PM
rhdune16
Sep 28, 2015 11:31 AM
