help with viper 791xv
i am trying to install the viper 791xv in my 2003 acura tl. Does anyone knows the color codes from our vehicle to match with the viper
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |passenger fuse box *1 |
| POWER UNLOCK|orange |- |passenger fuse box *1 |
| LOCK MOTOR|white/red | |drivers fuse box *2 |
| UNLOCK MOTOR|yellow | |drivers fuse box *2 |
| DISARM DEFEAT|lt. green/red | |passenger MUX module *3 |
| PARKING LIGHTS +|red/black | |passenger kick panel |
| PARKING LIGHTS -|red/yellow | |left of steering column |
| HEADLIGHTS|blue/red |- |left of steering column |
| DOOR TRIGGER|black/white |- |passenger fuse box |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|blue/green |- |drivers fuse box |
| HOOD PIN|yellow |- |passenger fuse box |
|TRNK/HTCH RELEASE|white/red |+ |passenger MUX module *3 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|blue |- |drivers door key cylinder |
| TACHOMETER|blue | |drivers shock tower *4 |
| SPEED SENSE| | | |
| BRAKE WIRE|white/black |+ |brake switch |
| HORN TRIGGER|lt. green/blue |- |steering column |
| WIPERS|blue & blue/yellow |- |left of steering column |
| LF WINDOW UP/DN|red/yel - red/blu |A |drivers window motor |
| RF WINDOW UP/DN|blu/wht - blu/yel |A |RF window switch |
| LR WINDOW UP/DN|red/blu - red/yel |A |LR window switch |
| RR WINDOW UP/DN|red/blk - red/yel |A |RR window switch |
| SUN RF OPN/CLOSE|grn/yel - grn/red |A |relays left of fuse box |
| RADIO 12V|white/green |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|white/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - gry/wht | |radio |
| RR SPEAKER|red/yel - brn/wht | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U. *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test. *2 Located in a green 18-pin connector. *3 The passengers MUX module is located behind the glove box. *4 In a 2-pin connector near the air intake on the drivers side shock tower.
This is for the 02 tl type s, i'm guessing it's probablly the same.
| SPEED SENSE| | | |
Notes:
AgentDSS
17
04-11-2004 11:40 PM
