Help - Question about changing Transmission Fluid
I have had three different people tell me three different things about changing transmission fluid. Acura tells me I need to have the transmission flush, Honda tells me all I need to have done is drain the fluid and not have the flush, and that the flush could actually do more harm than good. Honda didn't want to do the work, so there motive for telling me this is not in question, however, Acura would gain by having me do the flush, because it would cost about three times what a normal draining of the fluid would cost.
What is the answer here? Do I need a flush or not, or can I get by with just draining the fluid? Thanks.
ATF flush
I just did a regular drain on mine at 10, 000 miles but I did it 3 times over.
Meaning, I drained used ATF and refilled with new HONDA ATF ; with engine running, shifted to d5 put some load on the engine with my foot on the brakes, to neutral ...to reverse ...load engine again for about 15 sec. Did this 5 times then drained fluid. Refilled fluid again to specs.......so on and so forth until drained ATF fluid turns from dark brown(dirty) to pinkish color(clean) .
I was just charged regular rate of 24.95 but I bought my own honda ATF of about 12 qts .......10 bucks tip.........car runs great.
Re: ATF flush
Axleback
/etc/car
I'm going to do my own 30k service...
1) Flush the coolant
2) Clean air element
3) Replace micron filter
4) Flush ATF
When I do the ATF flush, I'm going to:
1) Drain it, refill with 2qt.
2) Drive through the neighborhood using all the gears, take it onto the side road to speed up to 5th gear.
3) Repeat that process 3 times
4) Refill with 2.6 qt (or whatever the capacity is).
I hope I don't get burned...I've never worked on a hot car before...I did the oil change with a cold engine.
4) Flush ATF
Just so that I don't screw this up, where exactly is the draining plug for the transmission fluid? Do you use only Honda ATF? There are no filters to replace like an oil change right?
axleback
axleback
4) Flush ATF
4) Flush ATF
The drain bolt is gold colored (cad zinc) and is designed so that a 3/8 square ratchet extension fits. It's on the drivers side. There is a fill bolt on top of the trans just behind the ATF dipstick. It's marked ATF. There are no filters. Just replace the plug washer. The procedure you outlined is correct. You'll need 9 qts of ATF and the drain plug washer.
Use only Honda ATF (Z1). Nothing else works well.
/etc/car
It'd be nice if Tim sold drain bolt washers for the oil and ATF...it'd probably work out to $0.30/washer and $1 postage.
Noone around here has the washers, and shipping is absolutely terrible for just washers...
While watching my dealer tech do my alignment I asked about ATF management. He said the system holds about 6 qts of which only about 3 drain out. The recommended Acura drain interval is 30,000 miles. He said the techs there recommend draining/replacing the 3 qts every 15k miles, then the full flush at 30k is not needed.
Makes sense to me and that is the plan I will follow.
given that many people seem to have trouble with their trannys on this site, i decided to go conservative and had the fluid changed at 10k miles. The tech said the fluid was real dark but fortunately the magnet had no metal particles (most all trannys have a powerful magnet that is literally just stuck in the pan to catch bits of metal). I will probably change my fluid every 15k thereafter. I know i can do it myself too, but Acura charges only $60 total for the job and they are open on saturdays by me for service, which is convenient, so its not worth getting the garage floor all messy at that price. Incidently this will be the first car i have ever owned where i did anything to the tranny at under 100k miles. I have never had a car where i had to worry about the tranny until reading all the horror stories on this site about the TL tranny. I am exercising greater caution now. I hope it helps.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I only have 10K miles on my 02 TLS....I did the drain and refill procedure 4 times @ 5K miles and used Amsoil Synthetic ATF. It works great....no noticeable shift differences from the Honda ATF.
Re: Re: ATF flush
Originally posted by axleback
So, did you do it yourself or bring it in for service? I'm at 22,500. Does it sound like a good time to get it flushed?
Axleback
Axleback
LOF at 5000 miles.
I just go to EZ lube for the oil job.
So far I'm happy with them.
juniel
Re: Re: Re: ATF flush
Just so maintenance is convenient and easy to remember, I do ATF and radiator flush every 10,000 miles;
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
