Help Not the usual Transmission problem
I have a 1999 Acura Tl That I swaped the transmission in with a KNOWN good transmission, but now the transmission will only go into 1 gear and after about 25 feet it will drop out of gear. No codes no flashing D4. Any suggestions???
01tl4tl (06-20-2015)
Mr.Helpful Diagram
+1 on low fluid. Check the level with engine warm and off, on a level surface.
For the '99 model, you're at 7.5Qt total capacity. DW-1 ONLY, fill to the upper mark when at operating temperature (radiator fan comes on at least once). Over/under filling can cause shift quality problems in our cars, the difference between upper/lower holes on the dipstick is about .5 Qt if what I've heard is correct.
FYI '00-'03 models is 7.6Qt total capacity.
mada51589
05-03-2022 08:54 PM
justin7779
12-25-2015 10:33 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
