Help: my tl failed to start
Hello fellow TLers!
Today my TL failed to start, I turned the key to start it and it started for a bit and shut off, it happend a few times then I decided to give a little gas and then it started.
The only possible reason I think it might of failed to start was because I was out of town today and I filled the car with some cheap gas i think it was regular gas (it was the only gas station insight) I usually always put 94 octane in my car.... do you think the gas affected the failure to start, or is it something else???
thank you
TL_RACER
thank you
TL_RACER
Did you not gas up the tank full? It happened to me once in a very cold day after I gas the car half full. Moisture can get inside the gas tank if it is not filled to full especially in cold days.
Originally posted by AcuraJoe
check your anti-theft system. make sure your car is reconizing your key!
