Help with HID fog conversion
Hey guys...I know you have probably had this question asked a million times, but here it goes again.....I have searched the threads and cant seem to find a D.I.Y. post step by step for the installation of HID fogs. If anyone could help me out it would be great.....Thanks a lot
its 100% plug and play supposedly but im not too sure about taking off the bumper and do i run the ballasts to the battery under the hood for the power?
Traded in my
Shit..where are you going for HID kits and installation. I paid ~$80 for DDM slim ballast kit shipped and installed it myself.
OP - If it's plug and play, you really do just plug it in and you're done. The only tricky part is where to mount the ballast.
2000 acura tl FPR
if you can, try to find a kit that has mounting holes on the ballasts, they provide doubleback tape, but i've had ballasts fall off (even when i cleaned the areas with alcohol), i mounted my ballasts in holes that were already there on the frame (i have a 2000 though)
Traded in my
^ Exactly what I did.
They'll fall off unless you use 3M tape and not what they give you. With 3M and good cleaning where you mount them, they should go nowhere..shit is STICKY!! LOL
'13 Hyundai Sonata
VERY easy install.
If the HIDs do not turn on the first time, then the +/- ma be on the wrong side. Just flip the connection around and it will work. Then just use a couple zip ties to hold the connection in place.
