help blower motor wont turn off
hey guys i know there are alot of post out there for this topic but non rely help so far.my blower motor(a.c) wont turn off no matter if i press off or not. it doesn't matter on the speed or temp it just blows air i replace the relay and resistor. the only thing i haven't replace yet is the blower motor itself. and the connect pice is good to and not melted .thanks guys if you can help
blower keeps on a blowin.....!
Hey Boybeasy, if your blower motor is running and blowing......than it's doing it's job !
So, moving along ......ya checked the harness and replaced the resistor pack along with the relay.
What's left ? Are ya sure that ya got the right relay ?
Maybe the auto climate control mix motor or temp sensor ?
Was it doing the same thing before ya replaced the resistor ?
If all else fails: try running the self-diagnostics by turning the key on, push the "auto" button and the "off" button......keep them both pressed in.
A problem will be shown on the "temp" digital display as an error code letter. Try this and if ya get a code, maybe that will help isolate the gremlin !
01tl4tl (11-17-2012)
I would suspect the connector-
did you physically open it up and inspect
ck for loose wires,,internal melting between the leads would explain your problem
Its not the blower motor itself--it operates when given voltage
the update connector kit is less than 20 bucks at dealer (Low as $12 from our sponsors)
what was the condition of the resistor?
hey 01tl4tl i look at the connecter it looks fine the only thing that looks bad would be the two prongs that inside the blower motor that the connecter hooks up to i did not open the blower motor but i did open the resistor and seen it was bad so i replace it with this TRANSISTOR ASSY(79330-S0K-A01) part and the relay( 056700-7410) can you please show me the update connector kit i haveint seen that ......as for 3.2tl no it didint work at all befor i replace the resistor when i got the new one it just blew air and never turn off unless i remove the resistor the blower motor it self is the only thing i didint check so far
update im getting constant power weather the unit is on or not also same for the ground the resistor good the motor good and relay good my buddy thinks it a wire touching idk we going to take another look in the morning tell them guys help me out please thanks
While I'm not 100% sure, but with an automatic climate control system.....the power may be available at all times for the unit. Are the AC~ cool and the heater~ hot both available ?
Checking all of the wiring connections and grounds would be a good place to start.
Have you tried the "self diagnostics" yet ? If the motor's terminal appears funky, it's possible that the wiring connector is at fault. Try an online "Acura" parts source for the part # of the updated harness.
if the car is on it blows hot no matter if i switch it to cold im going to post a pic of the blower motor to show you what i mean i have cut the old harness and made it so all i have to do is connect the positive and negative everything work untell now i take a pic to show you guys what i mean
call any acura dealer and ask for the TL blower motor power connector update kit
its the entire connector -comes with both sides and some wires connected
you solder in
Most common place for a short causing fan to run!
you solder in
