Help Bleeding!!
Old 01-09-2004, 02:05 PM
fred3113's Avatar
Help Bleeding!!
I am going to be changing my calipers and i was just wondering if i am only changing the front calipers , do i need to bleed the rear or just the front? and if i do need to bleed all the lines , what order do i do it in?
and how many brake fluid containers do our cars have, because i know on the 92 legend they have 2, one for the lines and one for the abs, is ours a similar setup?
thanx
Old 01-09-2004, 03:34 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
there is only 1 mastercylinder on our cars. you have to bleed ALL 4 lines. starting from the 1 furthest from the master cylinder moving your way around (passenger rear 1st, driver rear 2nd, passenger front 3rd, driver front 4th.) i would follow this procidure atleast twice or until all the air is out of the fluid
Old 01-09-2004, 04:26 PM
larryr20's Avatar
Exactly. Farthest to master then the closest.
Old 01-10-2004, 01:26 AM
04AcuraTL6speed's Avatar
There's alot of misconception about which order to bleed first. The common answer is most farthest away to closest to the master cylinder. At first this is what i believed too, since everyone on here states that.
But I bough a "1 man brake bleeder device" and it told me for a REAR WHEEL DRIVE car, you do it fartest to closest. But for a FRONT WHEEL DRIVE car, you do RR, FL, RL, FR. The reasoning is that the brake system is a "Dual Diagonal" system. If you go on Acura's website and look under the specs for brakes, it will say dual diagonal system.
I called up the service manager and he confirmed that for a dual diagonal brake system like ours, it would be best if you did RR, FL,RL,FR.
I know I'm going to get shot for this because everyone believes the other way is correct.
Old 01-10-2004, 08:41 AM
jpadilla's Avatar
I agree with you ... I hope I don't get shot too.
Old 01-10-2004, 11:39 AM
fred3113's Avatar
reply
i think just to make sure i will go to the acura dealer and ask the mechanic there, he should know! or if someone has a helm service manual could easily get the answer!!
Old 01-11-2004, 12:36 AM
medic's Avatar
on my maxima (fwd), it's a criss cross bleeding order starting with the wheel farthest away.
from what I remember about the reasoning, it had something to do with better stability is one of the brakes should fail
MonkeyTrucker
12-12-2017 08:59 AM
polish_pat
09-30-2015 12:22 PM
cacheflowe
09-14-2015 10:35 AM
HOWELLiNC
09-10-2015 01:39 PM
Quick Reply: Help Bleeding!!
