HELP: ABS and TCS lights on solid
#43
http://www.tomorrowstechnician.com/tt/tt100410.htm
"...remove ABS fuse #2 for three seconds to clear the fault code. Reinstall the fuse and turn the ignition on. The ABS warning lamp should now go off."
check your driver side and passenger side fuse panels. I found a "TCS" in the fuse panel in engine bay near the front passenger suspension (left of sway bar).
This is what I pulled for 3 seconds. Did not seem to do anything, however.
#44
For clarification:
Any of my post regarding brake pad bedding, ABS or TCS-
ALL testing should be conducted on lonely open roads with no other traffic
#46
Canuks- I think the cold affects them
#47
Just to follow up on this thread. To pull any ABS Codes, you can jump Pin 4 & 9. To help you locate them, Pin 4 is on the bottom row counting from the right. Pin 9 is on the far right and on the top row. I need to change my front right wheel sensor.
mada51589
05-03-2022 08:54 PM
