Help!!!!!!!!!!!!!
Help!!!!!!!!!!!!!
I just installed the panasonic tv/dvd unit & i by-passes the navi. Now only 3/4 of the navi voice comes out. what should i do. does any one have any tips,directions, etc..
Also, i forgot........... does the navi voice come from the front or back & which speakers. L or R or both.
Thanks in advance...........
i believe it mutes/lowers both front speakers for the nav voice. what you can do is tap one of the connectors on the back of the nav unit and wire it to a separate amplified speaker. you can also hook up the nav mute wire to mute your headunit so you can hear the voice better. i'm not sure how else you can reincorporate the nav voice. just do a search for the nav conversion and you will find the connector diagram.
