helms new mod
helms new mod
does anyone with the helms have a wiring diagram for where the map and dome lights run to where i can tap into it to do some stuff.....im doing a mod that some of you guys might be interested which is instaling a cold cathode in the dome light.....should come out brighter and more colorful.....anyone pleasse!!!
thanks
JON LERD
thanks
JON LERD
the dome light has 3 connectors, one is hot, one is direct ground, and the other is a ground that leads to the passenger multiplex control unit. This controls the ground so that the light is gradient, that is gradually dimmed to dark dependent on the programming of the control unit.
it dims dark after you remove the key from the ignition, it also dims after you disarm the alarm, and after you open a door.
I can scan the helms diagram and send it to you via email.
JLERD@HOTMAIL.COM
JON LERD
InFaMouSLink
10-27-2015 06:52 PM
lanechanger
10-13-2015 10:56 AM
