hello to all ...1st Question..keyless remote inst.
I would like to greet all on this site. I an a newby, so please be easy on me. I did a search on trying to find keyless remote programming instructions for a 2003 TL. I couldnt turn up anything for the 2003 model. Do u think a newbie could get a little help please. Thanks to anyone who replies.
Welcome to the forum.
I did a search and came up with these instructions
Keyless entry Remote can be program by doing the following, you must program all remotes at the same time,
else the remotes not included in the programming will not work.
Make sure the codes in the back of the new remote matches your old stock remote. Some key fob may look the same
but won't work with each other. Be sure to have all Key fobs you want working with you when you do this.
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or
onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter
lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter
code is stores. Make sure you program all transmitters you want working within 10 seconds of each other.
Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
***make sure the serial number on the backs match.....Program at your own risk***
Thanks for the help. I also found these same instructions................used them and it programs my original remote fine...my problem comes in when its time to program the other one that I bought. I push the lock button but it wont program. I have check the serial #'s prior to purchase and afterward. Everything there seems to check out............but it wont program the second one.
humm. dont know what to say. I cant find any info in the service manual on it.
Registered Charity
SinCityTLX
10-07-2015 01:24 PM
