Headlight restoration doesn't work?
I bought a kit for restoration, and tried going based off of steps I remember from a previous attempt (this was an Amazon kit, no instructions). I started with P60, went up to 100, 180, 240, 400, 800, 1200, 2000, 3000. End result was hazier, but not yellow. Came back to it another day, found some videos online, tried following them to exact instructions. 600, 1500, 3000, but still super foggy. Compound doesn't do anything at all. What can I do? I've spent probably about 4 hours trying everything on this
The better headlight
The one I can't fix
The one I can't fix
whitetiger5 (01-15-2021)
You didn't mention anything in your post about the clearcoat - that's what ties all this work together at the end. Without it you've just got a very uniformly hazy headlight.
Try to use a kit that comes with the clearcoat (I've had great success with the wipe-on clearcoat that 3M includes in their kits) or find a 2k sprayable UV-resistant one. If you haven't worked with spraying paint or specifically spraying clearcoat before, I'd suggest sticking with the wipe-on stuff.
RaviNJCLs
01-07-2024 09:20 PM
